SOURCE: wiring for fuel pump 95 jeep cherokee
I believe that the power wire is black with orange tracer on it.
SOURCE: I need to check power to my fuel pump on 98
Pic, Hope you can read it.
Testimonial: "Thanks, it helped some but didnt solve my problem,cannot read the diagram too fuzzy, need to know what color the fuelpump wires are?"
SOURCE: How do you check voltage on the fuel pump on a
Hello Dennis.
When you are checking fuel pump voltage on your pickup when you turn on the key the voltage is only applied to the pump for a couple of seconds unless you go to cranking position.
There are 4 wires leading to the fuel pump on your truck. The gray wire is the 12 volt positive power feed to the fuel pump and the black provides the ground. The orange and purple wires are your fuel gauge wires.
The relay for the fuel pump is in your under hood fuse panel and I believe is marked on the underside of the fuse panel cover. It should click on and off again quickly when you turn the key to "on". Having a helper to cycle the key would be handy while you put your finger on the relay and listen to it. Just because it clicks still doesn't mean it's functional but relay failure on these models is somewhat rare.
I would start by checking for power at the fuel pump harness.
Fuel pump issues are quite common on these model year trucks.
Hope this helps you out.
SOURCE: 1994 jeep wrangler 6 cyl 5 spd no start
have u ck out the ignition switch [not the key & tumblers],, or the neutral safety switch to see if u have power ,,also seen broken wire at solenoid on starter too,,hope it helped,,
SOURCE: 2004 Jeep Liberty 3.7 liter 4 cylinder.clicking,tapping,wont cran
Does sound like it has blown up
