Hello, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Best wishes
Mac =)
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET. you must go to the repair shop TV for fix it. However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof God bless you.
Possible explanations and work-arounds based on various blood pressure
monitors..net is if it has worked religiously like mine had and this
error comes up, and the simple fixes below do not work, there is
something internally wrong with the unit..there does not seem to be any
customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Hi there
I cant see much about this error you have the only thing I see about it is it could be the software driver or your windows need updating just try re installing your driver you may need to unsiall the driver first. All the best
