Question about Palm Treo 755p Smartphone
    Problem Solver:
  • 6 Answers
Probably an incompatible app you recently installed. Try deleting the app. If all else fails, you might try doing a hard reset. Make sure your data is backed up since a hard reset wipes out ALL data.
Posted on Nov 20, 2007
  • 59 Answers
I was thinking the same -,/
Article ID: 26419 HELP - spacer.gif Fix a device that's looping, flashing, or frozen on the Palm Computing Platform logo
If your device encounters a system extension that is corrupted or contains an error after a reset, it will automatically reset and try to load the corrupted extension again, which causes it to reset again, and so on in an infinite loop.
"What's a system extension?" you may ask. System extensions are software programs loaded the first time your device starts after a reset. System extensions extend the functionality of your device; for example the software that allows your device to send data through the Infrared (IR) port is a system extension.
Break out of the loop
To escape from the loop, perform a system reset.
If the looping or freezing is related to an application or extension, a system reset will only temporarily resolve the problem.
Diagnosing problems by 3rd party apps-
Posted on Jan 08, 2008
"access powered" after the "palm screen"...keeps doing the same thing over and over
you have to hardreset your phone it will wipeout your all the data. but it will work
1. Disconnect the Treo from a charger or USB cable.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p is hard reset.
Jun 22, 2010 | Palm Treo 755p Smartphone
4 2 months now, treo 750 keeps hanging up
i think is time for a new phone. sorry
May 02, 2009 | Palm Treo 750 Smartphone
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
Pls i need ur help
First off you must uninstall any previous drivers then reboot and install the proper drivers when drivers installed reboot sound should work
as for the other problem the sound driver can cause conflict with it
doing the above may solve both problems
Please leave rating
Jul 25, 2008 | Computers & Internet
Palm Treo Rebooting After send an Text/SMS
Hello, hope it helps (from
The application that causes the reboot varies, but it’s always the same error related to the message store. Here’s how you fix it (and beware — this deletes all the text messages on your device!):
  1. If you don’t already have it, you need to download and install FileZ on your Treo. All this does is give you access to all the files on the Palm OS filesystem. This is a tool that must be used very carefully, since you can move, copy, and delete any files on the Treo, even ones you didn’t know were there. It’s one of the most useful Treo utilities you can have.
  2. Run FileZ on your phone and choose “View and Edit Files.” In the next screen, you should see “Internal” under Filename. It might also say “ROM.” If you have an SD Card, you should also see “External” or “SD Card.”
  3. Click on the little wedge beside “Internal” to expand the list of files on your Treo.
  4. Find Messages Database and delete it (you do this by checking it, choosing “Details,” and then clicking “Delete”)
Apr 01, 2008 | Palm Treo 650 Handheld
Resetting to Power Off
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 07, 2008 | Palm Treo 650 Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Treo 700
Mine did the same thing also would not charge. I called Verizon data center and they did not even go through a re-set, just sent me a new phone. It is a common problem with hardware.
Dec 02, 2007 | Palm Treo 700w Smartphone
Treo 600 - internet and email problems
backup your data and (if still in warranty) return it to Palm
Jun 07, 2006 | Palm Treo 600 Handheld
Palm Treo 755p Smartphone Logo
418 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
