Not compatible with 64 bit - Computers & Internet
  • Dick
    Dick May 11, 2010
    Is there a question about that? Most programs are compatible with 64 bit operating systems and processors, even if the program is 32 bit.
    Sniper:
  • 163 Answers
Plz explain your problem in detail
Posted on Jul 16, 2009
2 Suggested Answers
  • 154 Answers
SOURCE: Is a 64-bit windows compatible version available?
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Posted on Apr 01, 2010
Qc848enu-Compatibility issue in Win 7 64 bit
Hello
It depend on the CPU if it is 32bit or 64bit. Windows 7 64 supports 32 bit software and 64 bit I suggest re-installing the software. It depend on the software if they have 64bit and 32bit you should install the version your PC is. Sometime 32 and 64 bit are embedded in software.
Feb 05, 2014 | Logitech qc848enu.exe
Mx6955 processor support
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Aug 11, 2013 | ASUS Computers & Internet
Need a driver for Windows 7 64-bit for my Belkin f5u109
No, this product is not compatible with Windows 7 - 64 bit. It is compatible with Vista 32 bit computers. however u have a similar adapter which is compatible with Vista 64 bit, and Windows 7 - 64 bit you can use part F5U257 (USB-to-Serial Adapter).
Aug 13, 2011 | Belkin USB PDA Adapter (F5U109EA) Serial...
Is Windows 7 compatible with HPlaser jet 1020?
Yes it is compatible with Windows 7. According to Microsoft website, it should be compatible with both 32 bit and 64 bit. You can check it if you want from the list posted below.
Windows Hardware Compatibility List
If you are not sure if your system is 32 or 64 bit, check your system information utility (windows key +, then type msinfo32). If it says something about x86, it is 32 bits or if it says 64 then it is 64 bits. Drivers for both are available below for you to download.
Microsoft Windows 7 (32-bit) driver
Microsoft Windows 7 (64-bit) driver
Jul 09, 2011 | HP LaserJet 1020 Printer
I cannot install arcview 3.2 gis on my laptop just because my laptop is 64bit and yet this arcview 3.2 requires only 34bit system!
Hello - You have the idea of the nature of 32/64 bit operating systems somewhat confused. 32-bit does not mean it is inherently downwardly compatible with 64-bit. To the contrary, much 32-bit software is not compatible.
64-bit versions of Windows try automatically to run in a 32 bit compatibility mode called WOW64. It couldn't work with Arcview. The actual problem with 3.x is that it has a 16-bit installer and no 16-bit software will run on a 64-bit OS. I checked at the ESRI website and the issue has not been fixed.
If Arcview is essential for you to run then it could be addressed by making your system dual boot between 32/64 bit Windows versions.
Thanks for using Fix Ya
Mikeywaf
Mar 20, 2011 | Computers & Internet
Donot work in 64-bit windows7
Search proper driver from internet, make sure it support Windows 7 64-bit, because if its only compatible with XP/Vista you'll face same problem as before. Even it compatible with Win7 32-bit, it may don't work in Win7 64-bit.
Hope this help.
Feb 03, 2011 | Office Equipment & Supplies
Will this work with vista home pre with 64 bit?
hello, No this model is not compatible with Vista 64 bit. its compatible with only 32 bit Vista.
However there is a similar model which is compatible with 64 bit Vista and the model number is F5U257 (USB-to-serial).
link from Belkin confirming F5U409 not compatible with 64 bit.
http://en-us-support.belkin.com/app/answers/detail/a_id/590/related/1/kw/f5u409/r_id/166
Hope this helps,
Good luck,
Kind regards,
Amar Sondhi
Dec 11, 2009 | Belkin USB/Serial Portable Adapter...
64 bit?
I run Vista 64 bit with no issues at all. 64 bit is the future of the computer world. If software is made to utilize 64 bit operating systems the speed is quite remarkable. 64 bit Vista is still backward compatible with 32 bit so virtually all programs except for the oldest legacy stuff. Also 64 bit allows you to surpass 32 bit's 3 gigabyte memory barrier. Vista 64 can use up to 128 gigabytes. It may not seem important now ,but at the rate computers evolve it will.
Nov 28, 2008 | Computers & Internet
Compatibility between new computer and potential new printer
the x5650 is compatible with XP, Vista and Vista 64
Nov 26, 2008 | Office Equipment & Supplies
Computers & Internet Logo
273 people viewed this question
David Payne
David Payne
