Question about Nokia N73 Cellular Phone
Could not Save Log details
In my Mobile NOkia N73 i could not save the call details even though log details is set to save for 10 days..
And it is showing no space for new messages even though my inbox contains 0 messages.. how can i solve my problems..
Please help me out.....
Nokia e 52 does not save log
Try deleting files from phone memory......goodluck
Jun 01, 2012 | Nokia E52 Smartphone
I want to change my nokia 2690's internet connection
Good day. Erase the configuration settings and Reinstall the new configuration settings, then try to run the newly install setting for testing purposes.Seek a strong signal from your network provider to get fast connection. Or call your network provider operator then ask for configuration settings for your phone unit, I'm sure they will send you the configuration settings for free thru text message. Save as default to your phone then try to run. Thanks
Sep 11, 2011 | Nokia 2690 Cell Phone
Im using n73 mobile,ijust want know information about call summery duration during call..
Please follow below steps
To check the call duration of your incoming
and outgoing calls, press Menu , and select Applications >
Log > Call duration
To set the display of the call timers while a call is active,
select Applications > Log > Options > Settings > Show
call duration > Yes or No.
Thank You
Aug 11, 2010 | Nokia N73 Cellular Phone
Hi.. My nokia N73 is always showing as phone memory full delete some data.. i have done resetting the phone multiple time still it is showing same problem ..
try ( * + '3' + 'call button') hold this three keys and power up ur mobile without simcard dont leave the button untill u get the countries name for further details.be sure to save or backup data saved in your phone and memory card. this format will remove each and every file saved in your phone memory or memory card which cannot be restored if deleted once..
May 20, 2010 | Nokia N73 Cellular Phone
SamsungGT-S5233-A:How do i block message from a particular mobile
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Mar 03, 2010 | Samsung Star GT-S5233 Cell Phone
I need an instruction guide for a nokia N73
You can find the instruction guide from the below mentioned link. The first 2 would directly get you a pdf file which you can save on your system. The 3rd is a url which will also get you to the N73 manual page.
nds1.nokia.com/phones/files/guides/Nokia_N73-1_UG_en.pdf
nds2.nokia.com/files/support/apac/.../Nokia_N73_APAC_UG_en.pdf
http://www.nodevice.com/user_manual/nokia/mobile_phones/N73.html
Sep 11, 2009 | Nokia N73 Cellular Phone
I wanna urgently airtel mobile office settings for N73 nokia
type gprs to 56789. you will recieve a message saying that airtel mobile office is activated. now type MO to 2567 and recieve the setting .save it switch off your phone and on it press the 0 button and you are connected. you will be charged rs 20 per day to use this service. you can connect to any website using this moblile office
Feb 10, 2009 | Nokia 6070 Cellular Phone
Call log is not showing the name of my sim contacts
after transfering the contacts to ur fon copy all of them to memory card..there is an option for this.u cn do this by selecting all the contacts n then taking option s then select copy to mem card. after this  Format your mobile by using the followin method. switch on the mobile whilst pressing green, *,and 3 untill it shows formatting screen.
n then transfer ur contactes from memory card to ur fone.. u cn do this by goto contacts n then selecting option n then select copy from mem card.. now the caller name hould appear on the fone... thank you,,
Feb 04, 2009 | Nokia N73 Cellular Phone
To remove installation log
hi
may be you dont save any thing in the phone memory try to save some thing in your phone memory then see
thanks
your friend from fixya!
Oct 25, 2008 | Nokia N73 Cellular Phone
GPRS settings
i have Motorola w220 model mobile phone and mms, gprs activation setting how to save it
Apr 16, 2008 | Cell Phones
Nokia N73 Cellular Phone Logo
42 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
