Question about Vector Power On Board High Intensity Discharge Spotlight
I am looking for the AC adapter?
I am looking for the AC adapter for a flashlight Power on Board Model SLH100P
Hi, how long do you leave it pluged in to charge and what lets you know when it is fully charged? I have the 26 led Power On Board Bright Bar.
Posted on Mar 19, 2011
    Guru:
  • 1,326 Answers
Try a radio shack or electronics store. Take the light with you to insure you get the correct charger
Posted on Aug 09, 2009
Power switch for Casio key board not switching
Without knowing the model, age of the keyboard if it is moved a lot, etc it's hard to say. Most common problems are damaged power jack(or cracked trace on the supply board near the jack ), bad AC adapter, bad power supply board(shorted semiconductor, regulator, etc ) and rarely a bad power switch. You could try a new ac adapter but it might be a waste of money(if you have access to a multimeter check the output of the adapter before buying a new one).
Jan 02, 2015 | Music
Can i use this lap top with plug in and not a battery?? where is the plug in?
I BELIEVE so. Some laptops require the Battery to at least be in the laptop, whether they are good, or not.
Others will allow the laptop to run off of the AC adapter (Charger), with the Battery not installed.
Gateway Support > Gateway MD26 series of Notebook PC's > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2364
Click on the - Support Documents - tab.
(Drivers / Applications / BIOS / Patches / Support Documents / etc)
Click on - Product Views - in the list.
Click on - Left View
Power connector
This is where the AC adapter (Charger) plugs in.
Examples, (Note US and Europe have different power plug ends),
http://www.batterytech.com/products.aspx?category=ac_adapter&brand=gateway&model=MD2614U&pid=AC-1990111
[The laptop uses DC electricity. Just like the Battery it has, and flashlight batteries. DC Voltage.
The AC adapter (Charger) converts your household, or business, electricity from AC to DC.
(19 Volts DC. In comparison two D cell flashlight batteries store 3 Volts DC ]
Regards,
joecoolvette
Oct 15, 2012 | Gateway MD2614u Notebook
I NEED A REPLACEMENT AC ADAPTER FOR MY VENTURA 7'' DVD PLAYER MODEL PVS12706E,
I recommend you contact your supplier manufacturer, and order the AC adapter.
God bless you
Aug 06, 2012 | Televison & Video
I need a charger for my Power on Board Sport Spot.
BLACK AND DECKER I THINK BOUGHT OUT VECTOR - BELKIN MAKES UNIVERSAL AC/DC POWER ADAPTERS MODLE F3A114 IS THE ONE I USE - HOPE THIS HELPS! MATTHEW
Jan 11, 2011 | Vector 20 Million Power Series Spotlight
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
Need a new sel ac Adapter Class 2 Transformer Model: KA12D120030042Ufor VEC141Y for a Sport Spotlight large flashlight old adapter is ruined
You can order the transformer from Black and Decker either online or you can go to one of their Service Centers located around the country.
Vector sold all of their prodduct line to Black and Decker in 2006.
May 21, 2010 | Vector 2M Pwr Rch Spotlight
Power failure issues
The specs for this monitor is a 60 Watt, 12 Volt, 5 Amp power adapter. The voltage must be the same. You can always get an adapter with a higher Amperage rating, but never get one with less, as this can overheat the adapter and damage it. I was not able to locate specs on whether the voltage to the monitor is DC or AC... most are DC. If this is the case, the observe the polarity at the monitor. Power adapters have a positive and a negative... center and outer contact, Make sure that the power adapter matches that of the monitor, else it will not work.
Sep 26, 2009 | Balance CM2017 17" Monitor
Green Light turns off when plugged in to the computer.
hi bro what u need to do is ... understand when u plug in the ac adapter the light on the ac adapter goes off and whne u unhoook it it comes on .. right there is a possible static charge in the mobo bcoz of which the ac current is nt able to flo on thru the wires to the motherboard .. what u can do is turn ur laptop off completely unhook the ac adpter and take off the battery as well press the power button for 15 sec press and hold it do this xcersice .. hook every thing up and try to charge the battery again it should work .....second possible thing can be may be the connectors on the mobo can be bad on the pin in the prong on the ac adpter must be twisted ,,, so check for that as well ...if still no go then either problem with the onboard power connector on mother board or the whole mother board power aseembly IE replace the mobo ....
cheers
Mar 13, 2009 | Dell Inspiron 6000 Notebook
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
No Picture
Put a flashlight up to it to see if you can see the screen working. The lights for the screen may not be working. Usually the inverter board or bulbs are burned out. You can light up the screen with a flashlight and see the "output" from the pc but it will be very hard to see.especially during the day.
Nov 04, 2006 | Dell 1503FP 15" LCD Monitor
Vector Power On Board High Intensity Discharge Spotlight Logo
1,348 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
