Question about Whirlpool Dryers
Drying Machine Problem
My drying machine is spinning, but it is not drying
    President:
  • 942 Answers
Hi..
If your dryer is not drying,
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating elementOften a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Regards
PCmania
Posted on Jul 16, 2009
  • 5,911 Answers
If the Thermal Fuse were blown the dryer would not run at all. The following link explains how to troubleshoot a dryer not heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat related problems are attributed to poorly installed, kinked or clogged exhaust vent ducting. Pay particular attention to the section that discusses ventilation and make sure your dryer interior and ducting are clean. Leaving a dryer in a clogged condition will not only decrease the drying efficiency of the appliance, it will also cause repeated failures of any components you may replace and is a fire hazard.
The first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If you have any questions about this repair, or require additional assistance please let me know.
Posted on Jul 20, 2009
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
Noisy squeel when simpson ezeset 550 washer is spin drying
You need to determine if it is the drain pump or not, these can squeal when pumping due to wear inside, if it is not coming from the pump then it could be either the belt or worse case it is the drum seal. It's just a matter of pinpointing the noise
Mar 10, 2012 | Washing Machines
Washing machine stop draining and not spin drying
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 21, 2011 | Samsung Washing Machines
Washing machine is washing but not spin drying
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 11, 2011 | Washing Machines
Hi the problem is the washing machine not drying or spin
heatman101
Sep 08, 2010 | Washing Machines
The spin drying is not drying properly so there is alot of water in the clothes
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 07, 2010 | Westinghouse WWS833ES Super Capacity Top...
Does not spin dry
heatman101
May 20, 2010 | Haier XQBM22-C Top Load Washer
The Washing Machine is not drying
heatman101
Dec 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Dryers Logo
195 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
