Question about Brookstone 538744 Remote Control
How do i program my brookstone remote to my toshiba regza flat panel?
  • 403 Answers
Try this, just be patient as it may take a couple of minutes to program.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 30, 2009
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
Need a code for toshiba 42 in tv for a dish network remote
The dish remotes only have a limited number of codes, if not there remember not all remotes will program all sets....
Oct 16, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA takes 20-30 seconds to turn on w/ remote
hard to turn on?, check weather their is a bulging electrolytic capacitors at the power supply board.
Sep 30, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
How do i turn the Panel lock function off on my Regza 42xv600a without the remote?
This may not be possible; it may be designed to prevent children from operating the set without an adult with the remote present.
You can probably buy an original remote or a known substitute from:
Remotes.com
Sep 10, 2011 | Toshiba REGZA 47HL167 TV
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Jan 17, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba Regza tv was in storage we took it out and can't find remote is there a way to tune without it? Thanks
Yes,must use the manual control on the tv itself.Very trouble some.Buy a new exact remote on website 1-800-Remotes Factory Original.
Jan 16, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Brookstone 538744 Remote Control Logo
168 people viewed this question
Top Brookstone Televison & Video Experts
L Pfaff
L Pfaff
Tom Chichester
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
