Question about Sony PlayStation 2 (PS2) Console
I was told nail polish and swab just dabb the laser
Me 2
  • 716 Answers
Do Not Use Nail Polish You Use Alcohol And Or Nail Polish Remover if no alcohol is available. Put some on a q-tip and dab very lightly until dry. Do Not Push And Don't Spin The Q-tip.
Sincerely,
Michael Scott
Posted on Jul 16, 2009
How do I remove super glue from my skin?
Acetone is often found in household nail polish remover, and a small amount on the end of a Q-tip applied directly to the glue should dissolve the bond without damaging the skin. How to Get Super Glue Off Your Skin
Do not use a cotton swab, as this can react very violently with cyanoacrylate
Do not do this on sensitive skin (e.g. lips, eyes, nose) or near an open wound
Other method if you dont have acetone with water & shave cream The Best Way To Get Super Glue Off Your Skin
Dec 11, 2014 | Cars & Trucks
Tip
Tip To Remove Nail Paint Easily !
Have alook at some of the easy and handy ways to remove the nail polish.
1. Dark nail color
Taken aback? Well it is true! If you have a deeper shade of nail paint than the one existing one, you can use it as a paint remover. Apply the darker paint to your already painted nails generously and immediately remove it off using cotton balls. Make sure to be quick in doing it so that the paint does not have sufficient time to get dried.
2. Perfume
Love to wear perfume? Well, here we give you have another reason to buy them. Regular perfume will help you a lot in getting rid of your nail color. All you need to do is dip a cotton ball in a generous quantity of perfume and gently rub the painted nails with this. This requires not much pressure and one can get their nails paint-free instantly.
3. Body Spray
If you happen to find the bottle of your nail remover empty, consider the bottle of your body spray for the same purpose. Place the bottle in such a way that the nozzle remains just a few centimeters away from the nail. Now, spray it on your nails and slowly wipe off your nail color by using cotton ball. Repeat the same process for all other nails.
4. Dry cloth and warm water
Take some warm water and put the fingers in it. Wait for the polish to soften enough (this should take about 20 minutes), and then, take out the fingers from the water. Using a dry cloth, gently rub the nails. The color will disappear.
5. Vinegar and lemon juice mixture
Replace the acetone-filled polish remover with a very easy and simple home remedy which is safe. Take 1 tablespoon of lemon juice and mix 1 tablespoon of vinegar to this. Blend both well together. Then, dip a cotton swab into this mixture and gently rub the painted nails using this. Spending about 10 to 15 seconds on each nail will remove all the traces of the old polish efficiently.
on Jul 15, 2016 | Health & Beauty
Not recieved yet
If u used your credit card or Paypal, file a claim with them.
Apr 19, 2014 | As Seen On TV Gel Haute Nail Polish Kit...
Can you use polish on top of the temptique nail repair
Temptique' Brush On Nail Repair is excellent for making weak nails harder and stronger...especially if you naturally have weak or thin nails.It Helps polish and designs last longer.
Mar 26, 2014 | Temptique 2 Pack of Brush-On Nail...
My mum decide my sewing machine need oil but instead of oil she accidentally has put superglue instead.. Honest mistake.. Is there any chance I can fix this or do I bin it.. Please will try anything...
try nail polish remover
Acetone
  • Acetone, found in many nail polish removers, is the most effective way to dissolve super glue because it works on a chemical level to break down the bonds. Simply wipe the glue with a paper towel or cotton swab, removing it layer by layer until it is completely gone. Do not use acetone on plastics, as it will damage it or even eat through it in some cases.
Mar 18, 2013 | Sewing Machines
Hi, I recently bought a bottle of Salley Hansen "No More Breaks". Found that the polish chipped off as soon as my hands came into contact with any form of soap. Be it shampoo or dishwashing...
Well, if you have this problem with all nail polish, then you can safely assume that the problem may be that you have oily nails - in which case your nails will secrete oils that lift the nail polish off your nail, causing it to chip.
BUT
If you are only experiencing this problem with this particular bottle of Salley Hansen, then it is likely that it may be a formula problem.
For both instances, try using a primer and a base coat polish BEFORE applying the Sally Hansen. This will improve the adhering of the polish to your nail no matter what the problem is.
Sep 19, 2011 | Health & Beauty
I follow these commands to play the game, "open tray, "close tray", then is says "reading disc", and then it says "open tray".....It continues doing this and then all of a sudden it will work SOMETIMES! ...
Your dvd player may be dirty or your laser may be going out, either way, if it's under warranty send it to microsoft for repair. If you want to tackle it yourself( you will void the warranty so think twice about it) then open it up, remove the dvd tray, open that up and clean the laser with alcohol or nail polish remover and a cotton swab, with only a slight amount of pressure when cleanning the laser, you don't want to throw it out of alignment. Put back together and hope a dirty laser was problem.(most of the time it's a dirty laser and sometimes it's hair that gets into the spin motor)
Apr 13, 2010 | Microsoft Xbox 360 Console
MY XBOX WONT READ ANY DISCS AND KEEPS POPPING UP WITH " OPEN TRAY" ...WHAT CAUSES THIS. ITS LIKE THE DISC DOESNT SPIN
either your dvd tray drive motor is dead or stuck, or the main reason is that the laser may be dirty or dead. cleaning the laser with alcohol or nail polish remover and a cotton swab sometimes fixes the problem. if not then a new dvd drive is needed. it has to be the excact same model. switch out the pcb boards and it should work perfectly. you need to switch out the boards because the dvd drive that is currently in your system is coded specifically to you 360's motherboard, so switching out the dvd drive alone won't fix the problem, now all this assuming your 360 didn't work after cleaning the laser and inspecting the motor for obstructions.
Apr 01, 2010 | Microsoft Xbox 360 Console
DVD PLAYER
Unfortunately that means the laser is weak or dead. It deads repair.
Aug 18, 2008 | Televison & Video
DVD PLAYER
Hope it was the non-acetone type of polish remover - acetone will melt plastic !!
Invest in a laser eye cleaning disk - the kind with the tiny brushes.
OK what type of file format are the files in on the disk you are tying to play?
IDM-1731 does not like .AVIs.
Check your documentation as to what type of files your player can actually read and play.
Sorry I'm not more help.
DW
Mar 21, 2008 | Initial IDM-1731 Portable DVD Player with...
Sony PlayStation 2 (PS2) Console Logo
226 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
