Chevy Avalanche 2002 2006 Factory Service Workshop repair manual
for the easy solution download the pdf file
SOURCE: 2003 CHEVY AVALANCHE dash board telling me left
check the lil switch that'll be located on the latch anchor point or within a few inches of it.... odd is the switch is faulty
SOURCE: solutions in fixing engine code 0446 on a 2002
check for a blockage in the line or piched if thats ok
then the is a fuel pressure sensor that can cause a p0446
you have to take the fuel tank out and the sensor is on the fuel pump module
you may want to take it and get the EVAP SYSTEM SMOKE TESTED
hope this helps
SOURCE: 04 chevy avalanche. failed inspection. OBD11
Hi, a P0446 means Evaporative Emission Control System Vent Control Circuit Malfunction
Full details @ http://www.obd-codes.com/p0446
SOURCE: I have check engine light on my 2002 chevy
That code is for your knock sensor which is located under your intake manifold. There are two under the intake. I would recommend replacing both, they are 40 dollars a piece usually plus the labor to remove the intake.
SOURCE: Lincoln ls 04 check enging light is coming on and wrench light
You will need a OBD2 code reader, that will give you a "trouble code" then that will tell you what direction to look in, for the problem.
