I have Bajaj Boxer AT and its engine is too loud. Some technical knowledgeable person say you should use 20W50 Engine oil in next oil change. is that oil is suitable for my motorcycle?
bike clutch plates are normally running in special oil as they are wet clutches
for them to burn they will be running dry
read the workshop manual and if you don't have one go google and type in workshop manual for bajaj motor bike boxer model- look for a pdf version to down load
Oil changes are all you need to do for engine lubrication. 10w40 motor oil is what goes into the gearbox. NEVER use synthetic lubricants in the engine. Thay can mess up the clutch. Please rate my answer. Thanks.
its either too lean(runs hot, causes vibrations, hesitates on acceleration) or there is a problem with the lubrication system(not enough oil to the piston = alot of friction=running hot. hope that helps
