Samsung Glyde SCH-u940 Cellular Phone Logo
Posted on Jul 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get that blue box back on my wallpapers
Jean Thiebaux
Level 2:
  • Expert 164 Answers
  • Posted on Jul 16, 2009
Jean Thiebaux
Expert
Level 2:
Answers
164
Questions
Helped
40994
Points
387
Go to display settings and cycle through you wallpapers
How do I change the wallpaper on these phones?
Go into your photos and select the one u shush to use as your wallpaper and usually if u tap on it it should give u options to set as wallpaper or you may have a blue box with an arrow through it on the bottom left corner or top left of the image. Tap this box and u will get option to set as wallpaper.
Sep 10, 2014 • Cell Phones
tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 • Computers & Internet
I cant change my desktop background ..
To change the desktop background:
1. Go to Start>Control Panel>Appearance and Personalization>Change desktop background.
2. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
3. Select the box next to the picture that you want to choose as your wallpaper(this will put a check in it.)
4. If you want the picture to fill the screen, under picture position, select "Fill."
5. Click "Save Changes." in the lower right of the window.
Another way to change the wallpaper-
1. Right click an empty spot on your desktop.
2. Click on Personalize. (This will bring up the personalization window with themes in the main window.
3. Click on the blue link "Desktop Background"
3. This will bring up picture location : desktop background. You will see boxes next to all the different pictures that you can select as wallpaper.
4. Then follow steps 3-5 above.
Hope this is helpful-Thanks for using FixYa.
Screen looks like plaid wallpaper, now blue with no sound.
I think the picture showing on your TV is like wallpaper, the T-con or Main board defective may cause that problem. “now blue with no sound” it tells you 99% the problem on the main board.
The part# you can see a sticker on the PC board, the format is like BN99-99999C. cost approx $180.
Knowledge obtain from: Repair experience on same symptom.
3helpful
How do i put wallpaper to screen size on the s5230
If you want to get a picture on the front of your phone do this:
Go to Menu--Settings--Display and Light--Wallpaper (If you have the picture in the wallpaper gallery then select it and click 'Set' and if you've got the picture in the different directory then go select 'images' and then go to the desired directory crop and click 'Set')
I would recommend this software Samsung Wallpaper Creator small in size but handy for creating wallpapers for your mobile where you can have 3 wallpapers in one and slide according to your choice on the phone.
Click on the link and go to the download Tab on the top and download the Zip file which is of 2.5 Mb aprox. Install on the PC and start creating wallpapers.You should use 240 * 400 size wallpaper aprox.each in the box.N you can always search for the pics on Google.
If there's more help you need let me know.
Good Luck.
Wallpaper changed to something blue with yellow and blue dialog
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
1helpful
Cant replace wallpaper
FOllow da steps
1>go 2 menu
2>themes
3>select whichever theme u want
4>go 2 options
5>edit
6>Select wallpaper as default
2answers
Cant remove my default nokia wallpaper
go to themes>edit>custom wallpaer (or something same)>browse to your chosen wallpaper...
give it a try,, and let me know...
Lost desktop pictures
You should be able to go back to the changed desktop picture (wallpaper).
Under Control Panel- personalization-desktop background, you will see a drop down box. upon pushing the picture location downarrow you will see where the pictures are.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
