Question about Compaq Armada E500 Notebook
While updating the ROM the process stopped and was told to retry and now when I turn it on I'm looking at 3 green lights and a blank screen like it won't even POST. What is the proceedure for restoring the ROM. I already tried unplugging the cmos battery which was no help.
    Problem Solver:
  • 10 Answers
I believe you were trying to upgrade your BIOS flashing it, and apparently it crashed in between the process. Now since the chip is only a Read Only Memory the upgrade takes place electronically. You might have either tried the wrong version of upgrade or have used a faulty driver. In this case you'll have to take it to the service center or to an electronic expert who can flash the BIOS and install the upgrade without booting into the OS.
I'd suggest taking it to the authorized service center.
Posted on Jul 16, 2009
  • 144 Answers
I have very bad news,it seems like you were flashing the bios,due to the process not finishing you have done irreparable damage to your motherboard.
My screen goes blank and system restarts at its own, cd rom is not ejecting out is not working, but icon is shown in explorer- dell inspiron N 5010, windows 8 pro, 3 gb ram, intel i 5.
Hi Harry010 , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? 1.) Did you recently perform any type of software upgrades? 2.) Did you recently perform any firmware upgrades? 3.) Did you perform any changes to the hardware by updating or changing drivers? Any of the above mentioned changes can affect the behavior of the laptop's operating system; including doing any automatic updates from Microsoft. Based on the limited info you posted with your inquiry, it sounds like there is some sort of driver conflict that is causing the OS to re-boot, perhaps in an attempt to restore itself to a previously known good start-up.
Dec 01, 2013 | Dell Computers & Internet
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
How to resetter error p07 for printer canon mp258
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press the button. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
Mar 01, 2011 | Office Equipment & Supplies
Canon imge class mf 4150 e225 eroor?
First:
Try to get the latest firmware at LINK.
Here is how to:
8. . Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
Feb 23, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Psp green power light on but blank screen
You most likely bricked it from an update. Depending on your psp's model you can diy a solution or your stuck with sending into Sony.
Apr 19, 2010 | Sony PlayStation Portable (PSP) Console
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
While im plaing my psp, the screen freezed and i restarted it, when i turned on my psp (theres a green light) nothing happens the screen is empty then a few minutes the green light gone what happened
I guess you have custom firmware. If so, you can use a pandora battery to solve the problem. If you do not know how to make a pandora battery or if this doesn't work send me an email or add me on eclipse_09_28@hotmail.com. But pandora is most likely to be the solution. I had the same kinna problem but I was updating it thats the only difference. The green light is on and the screen was blank and then the light turned off. So I used a Pandora Battery and it fixed. :P
May 24, 2009 | Sony PlayStation Portable (PSP) Console
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
Compaq Armada E500 Notebook Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
