Question about Motorola Mobility V600 / V620 Earbud Hands Free Headset
Security code locked
Locked security code locked
i mistakenly deleted a folder named "moto" and now i cant see no icons on my pone and everything just looks weird when messaging,etc.
0 characters
1 Points
How do I recover from a forgotten security code?
How to Reset Forgotten Nokia Security Code ' Technology ...
Oct 16, 2013 - Step by step instructions to reset blocked Nokia security code. ... Howdo i retrieve the security codes on nokia n9 in regard to track and protect system. i cant remember the .... Hi, I hv a classic nokia 1800 Type RM-653.
NOKIA 1800 - how to hard reset my phone -
Hard Reset NOKIA 1800; Then type this code: *#7370#; Now press your lock code. * The default lock code is 12345; Afterwards your phone will reset and ...
How to Reset Forgotten Nokia Security Code · Technology ...
How to Reset Forgotten Nokia Security Code. ... i dont see 5= in [308] now tell me what to do ... I Forgot my security code password in Nokia 1800.
Nokia 1800 hard reset
Dec 29, 2015 | Nokia 1800
I deleted software after it wouldn't work. I tried to reinstall. Software still in machine but won't reinstall over old software.No icons now. won't see it either.
Good day B J Gonce
Did you "delete" the software or "uninstalled" it? Because if you deleted it that is most likely what is causing the issue, whenever you want to get a software off your machine it is always best to go to the "Control Panel" and uninstall it from "Programs" if you have Windows 7 and from "Add/Remove Programs" if you have XP.
Where did you delete the software from? If you only deleted it off your desktop and or from your Star Menu then it has not truly been deleted. To get it off your machine you would have to search your Program Files folder and then delete the corresponding folders for the software you are trying to uninstall from there, but the correct method is to uninstall it from Control Panel like I stated above.
Nov 19, 2014 | Headsets
What is a code for imei 359400005078646 nokia n72
Hi what code are you looking for .if it is security code then try default code like 0000 or 1234 to reset it .If it network lock then visit here they ask you the network provider name to which your mobile is locked .finally they send you code to unlock your mobile.
Aug 19, 2012 | Nokia N72 Black Tri-Band GSM 2.0 MP Camera...
My security code for my nokia 1200 series
If you forget the security code, you get this error
DEfault code is 12345
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
Please rate this solution
Dec 03, 2009 | Jabra Earwave for Nokia 1200/...
Pairing moto H350 headset
Try and change pass code for new one
Feb 14, 2009 | Motorola Mobility H350 Wireless Headset
Samsung Glyde security lock code.
slide open and dial #43574357* and tap system info and the code is the last four digits of the "MDN".
Dec 31, 2008 | Samsung Wireless Headset for...
please ensure blutooth is on in the moto and the blackberry and its set in a "discoverable" mode..after that search for bluetooth devices in range and connect..if it asks for a PIN the usual code is four zeroes 0000
hope it helps!
Nov 02, 2008 | Motorola Mobility H500 Wireless Headset
Please change the disk name. your problem will be solved.
Sep 17, 2008 | Siemens M56 Earbud Hands Free Headset
same prob called provider and moto. they said its a device error n its 75$ jus for moto to look at it plus parts and plus s&h. im not wastin money on it. i went to my provider and got a new one before my upgrade was possible but got the upgrade fee. i didnt get a moto cuz of the problem. im happy with my blackberry. its  a little herder to manage around but its faster and it has more zoom and faster file transfer. Itunes to moto was slow, but now its like moving files from the comp to another folder on the phone the same speed as moving the files on the comp to another folder on the comp. Good job blackberry
Feb 25, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Open Questions:
See all Motorola Mobility V600 / V620 Earbud Hands Free Questions
Headsets Logo
24 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
