Question about Home Decorators Collection Charmglow Gourmet Luxury Island 84.5"hx95.25"w black
Hello I replace the gas tank and there is no gas flow. Then i replace it with a new one and again the same problem. The grill is less than 2 months old can it be the regulator?
  • 57 Answers
Yes it is a bad regulator go to home depot or lowe's to get one
Posted on Aug 27, 2009
When I start the grill, all burners are low and will not heat more than 200 degrees. i have replaced all 3 burners and still have the problem any answers?
Hello, Turn your gas tank valve off. Loosen and remove the regulator from the tank. Wait 15 or more minutes. Replace the regulator securely in the tank valve. Ensure ALL the burner valves are off. SLOWLY, I say again SLOWLY turn on the tank valve 1/2 turn. Try the grill again. There is a safety feature in the regulator that senses a gas leak; if the valve is turned on to quickly and to much pressure or gas flow is detected it will close down and the grill will not heat up as normal.
If you find this helpful please vote yes. Thank You!
Oct 17, 2010 | Char-Broil Advantage 463453306
Gas flow gets less and less till grill goes out
either the tank is bad/empty or the regulator needs replaced
Aug 16, 2010 | Weber Q Grill
Grill is one old and won't light. There is no gas coming from the tank to the grill. Is it the regulator?
age of the grill is irrelevant, i am old and i still can do few thingzzzz...
i assume that your regulator is connected directly to the bottle, then hose to your bottle, then hose is connected to the regulator and other end to the grill?
or it is bottle, hose, regulator, grill?
you need to follow the path regardless, be outside, light breeze is better, no open flame in at least 20m (yards) radius in any direction.
1. close gas bottle/tank
2. disconnect, everything from the bottle
3. crack open tank valve and hear if gas is escaping, close valve back
4. connect regulator to the bottle and again crack open the valve, hear if you have esacping gas, allow actually whiff of gas against your cheek or wetted finger to establish the flow. close the valve
5. connect hose to the regulator (procedure is reversed if first is hose and then regulator), crack open the valve, hear for escaping gas, check against wetted finger and cheek if there is flow, close the valve
6. connect your grill open all valves on it and open valve on the tank/bottle. allow free flow for about 30sec, close valves on grill. vent grill for about two minutes, try to ignite any of the burners. if burner ignite, you solved the problem, if they do not, and you did have flow on all previous stages, close bottle valve, disconnect everything from grill, clean grill valves and nozzles (burner have nozzle inside!), reconnect and vent again, try ignite, if ignition occures, you solve the problem, if not, then you are due for new grill...
if at any stage you do not have gas flow, this meant that this particular piece of equipment is in trouble, this particular piece of equipment need then repair or replacement, under no circumstance pull apart the reducer! NO OPEN FLAME DURING TESTING!!!
Jul 27, 2010 | Weber Q Grill
There is no gas flow to my burners. I have a new
Try replacing the hose and regulator, easy to do and inexpensive.
Jul 12, 2010 | Uniflame FG2204C Grill
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
No gas flow after replacement tank installed
You have a few options.
#1- Tank valve is bad.
#2- Regulator is bad.
#3- Disconnect tank from grill, hook back up, open valve slowly, see if gas is working. If not resort back to #1 or 2.
Opening tank valve to fast causes tank safety to shut down gas. By removing and reinstalling you reset tank valve. My guess would be #3. Then #2 if 3 doesnt solve problem.
Jan 16, 2010 | Weber Genesis E-320 Propane Grill
Flame is low
try opening the tanks slower so the overfill protection device in the tank won't kick in and restrict the gas flow.
Nov 10, 2009 | Weber Genesis Silver A Grill
BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Dec 05, 2008 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Home Decorators Collection Charmglow Gourmet Luxury Island 84.5"hx95.25"w black Logo
125 people viewed this question
Top Home Decorators Collection Grilling Experts
Paul Carew
Tom Chichester
Mohammad Navaid
Mohammad Navaid
Level 1 Expert
Are you a Home Decorators Collection Grilling Expert? Answer questions, earn points and help others
