Question about Alesis Sr 16 Stereo Drum Machine
Alesissr 18 drum machine lcd does not display
Alessis 18 drum machine lcd does not display words it powers up,sound works but cant read anythin on the lcd display
  • Alesis Master
  • 5,603 Answers
Check if there is a contrast setting... Unfortunately, sometimes the setting can;t be viewed when contrast is too low. Read your manual and find how to get into that mode if it exists and turn it up.
Posted on Aug 24, 2009
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
Alessi SR16 tempo slows down in stages throughout the song
I would start with double checking the "Clock in" and "Clock out settings. Also check that the Master sequencer is sending the correct Clock information. If you have not already done so, you can try by reinitializing the system (hold down erase-delete and record while powering up). If all that fails to remedy the problem you may have to check the SRam, some models have the high power ones fitted that drains the backup battery very quick. Change to the 58256-LP. Last but certainly not least, Avoid using any noise reduction systems (Dolby,or DBX) as these can distort the timing of the pulse train that contains the data. Have Fun.
Nov 07, 2013 | Alesis Sr 16 Stereo Drum Machine
I get a loud crack sound when I switch on the drum machine when I have it connected to the mixer
That would be normal - the order you power up equipment is very important. Always start with peripherals and work toward the power amp. Powering off is reverse - power amp first. You can also mute the mixer channel you're plugged into before powering up the drum machine but get into the habit of proper power sequence.
Oct 21, 2013 | Alesis Sr 16 Stereo Drum Machine
I have a DM5 18 bit drum module. It is a while since it was last used and I can't find the mains adapter. I bought a new one and have it set at 9V. The unit switches on but it is very dim and I...
You CANNOT use one of those universal adapters, period. The DM5 Alesis takes an AC output adapter. You need 9 VAC at 830ma or more. AC output adapters are hard to find and you are not the first to try a universal and find that they don't work! Here is one of MANY sources on Ebay:
http://www.ebay.com/itm/NEW-9V-1A-AC-AC-POWER-SUPPLY-ADAPTER-fr-Alesis-DM5-Drum-/110700117691?pt=COMP_EN_Networking_Components&hash=item19c63dbebb
Sep 20, 2011 | Alesis Dm5 Drum Module 18 Bit
ARE ANY TRIGGER PADS COMPATIBLE TO WORK WITH THE DM5 BRAIN
Word of caution: Other people have had a lot of trouble mixing different brands of triggers on drum modules.
Sep 07, 2011 | Alesis Dm5 Drum Module 18 Bit
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
Just got a SR-16 plugged it in an got boxes in the upper left corner of display. nothing else works. no sound nothing. please help
Make sure you have the correct power adapter for the unit. This unit takes a 9 VAC, 830ma adapter. It will NOT work with a replacement, universal or DC type adapter.
Jan 11, 2011 | Alesis Sr 16 Stereo Drum Machine
Can i hook the alesis drum machine up to my computer and use it to make beats?
Are you talking about recording the beats from the Alesis or are you talking about designing beats on your computer to load into the Alesis? If it's the latter, try this link:http://www.squest.com/Windows/Instruments/AlesisSR-16/index.html This link might also be useful:http://www.synthzone.com/alesis.htm Please let me know how you make out.
Nov 25, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
292 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Will Halftowaite
Are you an Alesis Music Expert? Answer questions, earn points and help others
