Question about Epson Stylus C46 InkJet Printer
I dont know how to put a printer cartridge . i need some videos pls
    President:
  • 828 Answers
No need to see some videos, its very easy to put a cartridges on Epson Printer, just go to the Printer properties and select Maintenance, you can see the an icon REPLACE CARTRIDGEs and thats how you do it, make sure your epson printer is on. Good luck!
Posted on Jul 16, 2009
My canon MP 145 printer displayed E5. How can I solve my problem?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 20, 2011 | Computers & Internet
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
May 06, 2011 | Canon PIXMA iP1300 Printer
Printer continually says put in cartridge even though I have (twice). I have checked over and over that the cartridge is firmly installed. Is there a sensor somewhere which needs cleaning or resetting?
Did you used refilled cartridge?
Sometimes for Canon printer, when u used refilled cartridges, they are not readable.
It's called E5 error.
In this case, you need to replace the cartridge with new one.
Apr 19, 2011 | Canon PIXMA MP130 All-In-One InkJet...
My printer which is a canon mp250 says error 6000 and the alarm blinks and the on button blinks i dont know how to fix it and if it needs to be repaired by a specialist I probley will not be getting...
As for the solution, pls take out the cartridge from printer.
And then wipe out the circuit part by rubbing alcohol (by Q-tip)
And then put your cartridge back to printer.
If above method is not working..... I think your cartridge circuit part must be shorted.
It happens when you refill your cartridge in Canon...(mostly for color cartridge)
This error is called e5 error, which canont be solved.
You can find the many solution for e5 but unfortunatley non of method can't fix the problem.
Well... as for immediate solution? Replace with new cartridge.
Apr 07, 2011 | Canon Office Equipment & Supplies
HPofficejetpro L7580 doesnt recognize cartridges have been replac
hELLO THERE
there should be a section there for the maintenance of the cartridges and change cartridges make sure that you use this whenever you change out a cartridge cause if you use this when you change out the cartridge the printer will always show low on ink also you can reger to your users guide for further instructions on how to do this ok? hopethat this has been very helpfull dont forget to rate my solution
best regards mike
(USN) retired
Aug 05, 2009 | HP Deskjet 6940 InkJet Printer
HP PSC 2355 CARTRIDGES INSERTED NOT INTENDED FOR THIS PRINTER
I have the same printer but my cartridges are Hp # 94 black
Hp # 95 Tri color
But I am in the U.S.A. I dont know why your" are a diffrent # for the same machine? odd, I hope This helps a little,
Mar 06, 2009 | HP PSC 2355 All-In-One InkJet Printer
Ink cartridge
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12764 heres the link just type in ink cartridge and it gives you step by step With pics.
Aug 01, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Epson Stylus C46 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
