Question about Singer AT7739 Lazer Storm Bagless Upright Cyclonic Vacuum
Singer as-01a Lazer Storm
I need to get a new filter/cartridge. The manufacture is gone. Is there a filter replacement I can use? The plastic is good so i can cut the old fiber material out but what material can I glue back in? Also what type of glue can I use?
  • trujil9 Mar 24, 2008
    I have the same problem with the Singer Lazer Storm Upright Cyclone Vacuum Cleaner. Where to buy a clear plastic dust cup(s) specific for the unit? I have never washed the filter on the cup, but merely brushed it off with a small brush. It works just fine. But I would like to have extra dust cups in case this one becomes non-functional. I have looked at many web sites and have not had any success in locating a manufacturer. I am actually thinking of placing a dust type vacuum cleaner bag type filter over the dust cup to see how that works. Any luck out there?
  • mom1949 May 23, 2008
    I,too, can not find a filter for this machine...what a rip is dirty and beginning to smell hot when I use it...I use a soft sponge (dry) to wipe it off and shake out the excess dust, but this will not work forever...I am really disappointed in Singer for fronting such a bad company and product...
Fed up having to buy new filters for your vacuum?
Over the years I've lost count of how many companies stop selling replacement filters for their long deceased production vacuum models or that filter replacements are becoming increasingly difficult to source. There are usually universal "microfilter" replacements which are easy enough to find and cut to size, but if you can't be bothered to do that, there are ways around to renew your existing filter even if the manufacturer or the user manual states that the filter cannot be washed.
You see, any filter can actually be washed - if it is a single cloth filter - as opposed to a micro pleated section of many layers sewn together. If you have such a filter, a single cloth filter which the user manual says cannot be washed, this is a blatant lie. Remove the motor filter as normal (usually found at the bottom where the paper bag goes) if it is embedded with dirt and wash under a hot tap of water with either household washing up liquid or soap. Once the filter has been completely cleaned, place the filter into a pillow case and chuck into an electric dryer on a low heat. Instead of waiting 24 hours normally for a filter to dry to room temperature, you'll cut your waiting time by a day simply by allowing the gentle heat from the electric dryer to circulate around the pillow case which holds your vacuum cleaner filter. Once the filter is completely dry to the touch and does not feel damp in any way, install back into the vacuum cleaner.
I have also done this with HEPA paper filters which apparently are not washable according to the manual, and to stop the plastic cartridges from bouncing off the walls of your electric clothing dryer/tumble dryer put an extra towel or cloth into the pillow case to minimise damage. What is then revealed is a new, dry and clean filter which can be used again instead of spending lots of money trying to source a new one.
At the same time, if your vacuum cleaner has a soft bag, take it off and put it into the washing machine to give it a clean lease of life - but you won't need to put it into a pillow case to dry in the electric dryer - simply chuck the bag in to ensure it gets dried properly before putting it back onto your vacuum cleaner.
on Nov 16, 2007 | Sebo Automatic X1 Bagged Upright Vacuum
How do I replace the Feed Drive Geer (Singer Part #174488) on Model 6234?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Singer Model 6235 Instruction...
I have an antique Singer serial number ABB01637 Any idea of the Model or year of this machine?
I cannot locate any Singer products with ABB prefixes. The AB prefix and the number you gave was manufactured in 1926 in Elizabeth, NJ. If this is the information you need, please come back and rate my response!
Jun 06, 2011 | Singer Vacuums
How old is the singer sewing machine with the serial number g1027369
You have a Singer Model 27, built at their Elizabethport factory in Elizabeth, NJ, in a production run of 40000 which were manufactured in 1911. Confirmation from Singer available by clicking here.
Your machine is very nearly 100 years old, but in good condition will still be fully usable and you can still buy many spare parts for it.
I trust that I have fully answered your question; please take a moment to rate my reply.
Sep 04, 2010 | Vacuums
Changing the two HEPA filters in the Rainbow E Series.
Plastic thing is fine. it probably has "e" in the middle...
To replace the motor filter you would have to remove cap. You have to get clear plastic lenses off the unit (you will need small flat screwdriver to release latches on the top of the lenses). Under those you will find a total of 4 or 6 screws. They hold the cap onto the main body. Filter is under the cap. See HERE if you need the filter.
Good Luck
Aug 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Singer AT7739 Lazer Storm Bagless Upright Cyclonic Vacuum Logo
456 people viewed this question
Top Singer Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
