Question about JVC PD-42WV74 42 in. Plasma EDTV
OPERATION MANUAL Please, I need to get the operation Manual for my JVC PD-42WV74 42" PLASMA.Answer me at cubalexcape@yahoo.comThanks in advance.
  • 1,463 Answers
Hi any look from ths site with the manual
Posted on Nov 18, 2007
0 characters
3 Points
Did you check with the manufacturer on their web site? If not available it is because the set was a special model for a large store - they change the model numbers on those sets so they cannot be shopped. You need to find the equivalent JVC model which asise from a different model number is identical.
They do NOT make special models for these big retailers - just give them a special number.
Feb 22, 2016 | JVC Flat Panel Televisions
Where can i find the user manual for the JVC PD-43N910 SMART 3D PLASMA TV
Did you check manufacturer web site? If not there, check out those sites that have tons of manuals for free download.
Color is Messed up on my JVC PD-42V485 There is More green then any other Color Help!!!!!
There are many reasons for this fault, that occurs with a plasma display. Without seeing its present screen, nothing can be adviced. If you wish to get more details about these faults to Plasma Displays, check this link. . It has screen shots to many faults that can occur to a plasma display, and measures to taken to rectify it. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | JVC PD-42V485 42 in. EDTV-Ready Plasma...
I have been given a JVC Plasma digital receiver and have NO idea what it is used for and what does it do please?Thanks in advance Lynn
Browse for an instruction manual. You will know all about it then.
I can't do it for you as you don't mention a model number.
Jan 29, 2011 | Flat Panel Televisions
Picture to big
don't sit so close...really...please be more prcise with your problem...use the manual that came with your set to change the picture size...maybe the picture zoom button has been inadvertently been pressed?? in that case keep pressing it till it changes back to the original size which is 1x thru the settings page. (menu button)
please be more precise with your problem... i hope this helped.
Nov 09, 2009 | JVC PD-50X795 50 in. Plasma HDTV
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
You will need to hit the aspect button using your remote. The unit sound like it is in Cinema Mode. You will need to change it to Regular. See the link below for the download of the manual. It describes this in more detail.
Instruction Manual Download
Mar 11, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
Blank screen
The X or Y drive boards are bad, the substain voltage is missing, or there is a problem in the power supply. Sorry, no quick fix here. Please call in a pro to assist you in this repair. Good Luck
Apr 03, 2007 | JVC PD-42V485 42 in. EDTV-Ready Plasma...
JVC PD-42WV74 42 in. Plasma EDTV Logo
234 people viewed this question
Top JVC Flat Panel Televisions Experts
Are you a JVC Flat Panel Television Expert? Answer questions, earn points and help others
