Question about Hitachi 50SBX78B 50" Rear Projection Television
Have a 50sbx78b had a blown e994. No lights red blinks. replaced e994 and q777 all lights came on the off b+ dim with red blinking.
  • Donald Chatman Jul 17, 2009
    replaced c707 all lights come on for a few seconds set resets its self about 3 or 4 times with all lights coming on then all go out and red continues to blink. will reset make a sizzlng sound like high voltage ark. Put meter on b+ voltage comes up then drops to about 14v each time it resets then 0v when it finally shut down. I thinking flyback but don't want to condem it till i'm postive that's it.
  • 3,741 Answers
E994= fuse, C707= .01uF/2kV.replace that fuse to fix the problem.this will help.
http://www.riddledtv.com/repair/hitachi.html
click the link directly and check out your model number in the list for more help.
replace C707 (blue cap) and the 2A pico fuse (E994). this will clkear the problem.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Posted on Jul 16, 2009
  • charlymonty Jul 17, 2009
    you think is right.but check out first.The current in the flyback primary and collector of the HOT are *not* equal. The horizontal deflection yoke, damper diode, HOT collector, snubber HV capacitor(s), and flyback primary all connect to the same point. We begin our adventure at the end of the scan - retrace - when the flyback period begins:
    1. At the end of scan, current is flowing through the flyback primary to the HOT, Q1. At the start of the flyback period, Q1 turns off. (This must be done in a controlled manner - not just a hard shutoff to minimize stresses on the HOT - but that is another story). Since current in an inductor (the primary of the flyback has inductance) cannot change instantaneously, the current is diverted into the snubber capacitor, C1. The inductance of the flyback primary (T2) and C1 forms a resonant circuit so that the voltage climbs on C1 as the current goes down. At its peak, this voltage will be 1000 V to 1500 V.
    2. C1 now begins to discharge in reverse through the primary of T2 (back into the B+ supply - the filter capacitor will stabilize the B+ output) until its voltage (also C-E of the HOT) reaches 0.
    3. If there were no damper diode (D1), this voltage would go negative and continue to oscillate as a damped sinusoid due to the resonant circuit formed by T2 and C1 (and the other components). However, D1 turns on as the voltage goes negative and diverts the current through it clamping the voltage near 0 (-Vf for the diode).Note that the damper diode D1 may have been built into the HOT T2 in the case of an inexpensive or small screen TV or even some monitors that don't have any circuitry for E/W correction.
      Steps (1) to (3) have accomplished the flyback function of quickly and cleanly reversing the current in T2 (and, as we will see, the deflection yoke as well). The full flyback (and yoke current) are now flowing through the forward biased damper diode, D1.
    4. At the beginning of scan, the damper diode (forward biased) carries the bulk of the current from the yoke and flyback. The nearly constant voltage of the B+ across T2 results in a linear ramp of current now through the damper diode since it is still negative and decreasing in magnitude.
    5. At approximately mid-scan, the current passes through zero and changes polarity from minus to plus. As it does so, the damper diode cuts off and the HOT picks up the current (with a voltage drop of +VCEsat). Current is now flowing out of the B+ supply.The base-drive to the HOT must have been switched on before this point! Timing is not very critical as long as it happens between the end of the flyback and the zero crossing of the summed current. The location of the zero crossing depends on the secondary load, notably the beam current. Larger beam current requires that the HOT be switched on earlier. The designer has to do some optimizing here...
    6. During the second half of the scan, the HOT current ramps up approximately linearly. This is again due to the nearly constant voltage of B+ across the inductance of the flyback primary.
    7. Near the end of scan, the HOT turns off and the cycle repeats.The HOT has a storage time between 3 us and 7 us, thus the base-drive is switched off earlier, in a controlled way to properly remove the charge carriers from the collector region in the HOT. The peak amplitude of the base current and the way it is decreased determine the ultimate dissipation in the HOT and are thus subject of heavy optimization. This is hampered by the fact that there is much spread in HOT parameters.
      http://www.repairfaq.org/sam/flytest.htm
      click this link and get more details
      thanks for updating.
Tv not turn on
Ur power board is dead.need a new one.
Sep 20, 2009 | Hitachi 50SBX78B 50" Rear Projection...
TV lost power - Protect LED D912 blinking
If E994 has continuity , then C701 is ok. defective C701 gives problem with colors and picture.
If there is no led flashing, and does not turn on at all then is the power unit, test the capacitors on the power board.
Sep 27, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Hatachi 60 inch big screen test port e994 open high voltage shutedown
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B). The kit includes the E994 pico fuse and the C707 capacitor.
Jun 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 60sbx78b Won't Turn ON...need advise
If cap value is 1000 pf ( 102k ) 2KV, beef it up ! I use Sony part # 1-161-754-00 ....102k 3KV.......Note: sometimes shorted cap
is hiding under dried gob of placement glue............
Make sure pico fuse is correct amperage.......T.
Jan 28, 2008 | Hitachi 60SBX78B 60" Rear Projection...
No power
You need to check E991, E994, Q777, for more info ctechnicians.com
Jan 09, 2008 | Hitachi 50SBX78B 50" Rear Projection...
My 50SBX70B doesn't start
There are many reasons for a no start on your 50SBX70. I will give you the most common problem I have found. Check E994( 4a pico fuse on the 120v line in pwr supply) If it is bad, remove C701(.001/2kv) from the circuit located near Q777. Inspect the capacitor for any burn marks, if so put in a new fuse and leave the cap out and fire up the set.
Nov 07, 2007 | Hitachi 50SBX70B 50" Rear Projection...
Red light blinks thats all
Check for shorted 102K/2KV capacitor near flyback transformer.Also,E994 fuse open. Replace cap w/3KV for durability.
Sep 29, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Will not power on......what could be the problem on the board?...i am good at soldering things...will replace if I new what to replace
If have already unplugged and waited for atleast 15min. and still no success. Then only if you are Electronicly inclined. Check to see if you get dead completely or you get an indicator light momentarly. Which these are two different symptoms. first dead no indicator. check R931,E994,Q777. Then if indicator light comes on and goes off, check E994 which is fuse opening, C707-1000pf 2kv cap, also check D915, I601, IK04, and 05
Aug 04, 2007 | Hitachi 55FX48B 55" Rear Projection...
Anyone know
Usually this occurs when the Convergence ICs go bad along with some chemical fuses mounted on the deflection board. E994 usually blows along with the Horizontal out transistor going bad. This transistor, I believe is Q777 that usually goes bad. The fuses are either tiny little yellow fuse with a red band or green with a yellow band depending on your model number
Jul 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
