Question about Emerson EWF2004 20" TV
Hello i lost my remote now i cannot operate my tv and now i can't play game or wach moveis because it doesn't go to the input channel what do i do
  • 3 Answers
Looking at yr tv, i thk it is the same model i have...i don't hv the orig remote.go to the menu, shd see "set-up", as you manually press the channels2.3.4,etc you have to save the channel.you probably didn't have to chg 3/4 saved b/c normally cable is hooked up.you set up is complete you will be able to manually(push buttons)on t.v. - but i have since gotten a universal remote
Posted on Jul 28, 2009
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
How to turn a symphonic tv into game
symphonic is well known for this-no buttons on unit for key features and a universal is not going to help either, suggest you go in search of the original remote and hang onto it.....
Aug 28, 2012 | Televison & Video
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
I haven't had a remote for my Symphonic T.V> in the couple years I have had it, but I have always used it to play video games on. I have never had this problem before, but now I can't get to...
Here is the manual for your TV. I see a Game Mode when referring to Picture control, but I'm guessing you are trying to get it to switch the the RCA input for Video/Audio on the front of the TV for your game console. Doesn't look like there is anything on the TV specifically, as it references the remote to press "Game" mode. But I would try scrolling down through the channels. Sometimes TV's have the auxiliary input below channel "1" or "0".
Jun 24, 2011 | Symphonic ST419E TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
Feb 16, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Lost remote
Sorry, got to have the remote for this set...accordianman
Aug 13, 2007 | Symphonic ST420FF 20" TV
Emerson EWF2004 20" TV Logo
354 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
