Bought three years ago, replaced light bulb one year ago and within 10 months watching t.v. and picture went out - took to an authorized rca repair shop and the outcome was the light engine was defected and needed to replaced; however part has been disconitued. have been given the run around by many customer service representatives and now wondering what steps i should take (ie how can i find a used light engine for 50 inch dlp rca hd television) fyi model number is M50WH7254X1 and serial number is G315C60F4. Or are there any other options, thank you for your time in this matter. You can respond to my email at emktaylor@yahoo.com
  • 3,741 Answers
There are two more options where you can get the compitable parts
as they have highest number of parts collections.
www.partstore.com
and other is
www.shopjimmy.com
click both the link 1 by 1 directly and check out.this will help.also more help will be to the junk old tv part store.you can just give your requirements their.they call when they receive the part.as this can be available in 15 days period.they get it here and there while buying old tv.and also they have good contacts with others who deal in this parts.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Posted on Jul 16, 2009
Why is the picture on my RCA tv goes slowly darker as i watch it?
Contact any service technician. Its CRT base connector socket, or, LOT is faulty. This is not a user repairable fault. Replacement to any one among component stated above, or both, might need replacement. Gopakumar Gopalan Google
Mar 05, 2014 | RCA Televison & Video
Purple band top half of DLP Rear Projection
Download its repair manual by internet, and check it.
May 12, 2013 | Televison & Video
Rca projection tv
The white dots indicate a problem with the optical light engine---Parts for this set are very expensive and my suggestion would be NOT to repair it but replace it.
If you want some more information Google the model with "problems" to see what the common issues are fot this set
Dec 07, 2012 | RCA Televison & Video
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Both of my headlights burned out about the same time a year and a half ago. I then replaced a few months ago, now the other one blew. It seems that these two lights both burned out too soon. Possible...
I've got a 2001 Elantra that "eats" headlights. Within the last five years, I've probably replaced both headlights 10-15 times. Last time I bought bulbs, the clerk at the Auto Zone recommended coating the connection points of the bulbs in electrical grease (which is different than regular grease). It's usually sold in small foil packages at the check-outs. Anyway, this seemed to prolong the life of the bulbs by 3-4 times. It's a cheap fix that didn't completely solved the problem, but sure cut down on the number of bulb replacements.
Aug 02, 2008 | 2001 Hyundai Elantra
Blue Screen w/Flashing light in the middle echoing out to edge
Good Day, you all;
This TV has many problems......at least three boards and many parts on each PCB..... most places charge between $750.00 to $1,200.00 to repair. So, I will let you be the judge if it is worth it. Get an estimate from an authorized service center be fore making final decision.
If you can repair yourself I will be glad to give you the info.....it takes an experience tech about 3 hours to repair.
Good Luck, big IRISH.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Distorted picture on RCA LCD TV
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Oct 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic rear projection TV 47 in PT 47WX49
Camaroguy: This exact problem happened to us about 8 months ago. A board had to be replaced at a cost of $500. Yesterday, the convergence has gone on the set. You get a blue and yellow shadow on the picture. From what I have been reading, this has happened on a few TVs and it will cost another $500 or so. We refuse to pour more money down the drain so we just went out and bought a new plasma (RCA) for half what it cost us for the Panasonic 4 years ago. We have never had a problem with RCA in the past (two tvs for 20 years a piece).
Mar 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Loose Picture (Goes completely Black)
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
May 16, 2006 | RCA MM32110 TV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
