Question about LG DBRH197H DVD Player/HDD Recorder
My DVD disc not recognized after loading, how can i fix it? our dvd wont read +r-rw now. it used to. then we bought a plasma tv now it wont read the disc we have
Re: My DVD disc not recognized after loading, how can i...
My dvd player when i switched on only stand by light on but the machine does nt respond.
Posted on Mar 13, 2008
  • 304 Answers
SOURCE: My DVD disc not recognized after loading, how can i fix it?
Try to use a optical disc cleaner for the player, this can only be a dirty lens thats why the unit cant read the disc inserted.,
Posted on Apr 13, 2009
0 characters
3 Points
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
Trying to record on dvd, using dvd-r dut says unknown disc what to do?
This is a comon one, RW Disks do all look similkar but, they do have diferent letters at the end of the name and if you have not bought the correct coded disk, your RW wil not recognize is. Sugest you read your manual and check what exact disks you need and check the pack you have bought.
Mar 10, 2010 | Sanyo DRW-1000 DVD Recorder/VCR
I recently have not been able to record on DVD+RW discs. An error message keeps coming up saying it cannot record on this disc.The dumb part about it is I still have a couple of discs of the same nature...
According to the user's manual, for DVD+RW or DVD-RW discs, it may take some time for the disc to be recognized and then it has to format the disc prior to using it. This should be an automatic process when the disc is inserted (looking at page 17 of the owner's manual). If this is not happening, you may need to clean the DVD with a DVD cleaner (a DVD disc with tiny brushes that wipe the lense on the unit while the disc spins). You could first try using a can of compressed air and blowing any dust/dirt out of the DVD slot (with the tray open).
Feb 09, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
I recently bought a Panasonic DVD Recorder DMR-EZ27. And it does not read blank DVD's. I've tried different brands of DVD-R's, DVD R's, and DVD-RW's. However it will play and recognize pre-recorded DVD's....
The problem still is;nt fixed. I bought the dvd recorder from a person that buys customer returns at an auction. I contacted him and he offered to give me a full refund or another recorder. He thought it might be a software problem.Thanks for getting back to us on this problem.
Jun 10, 2008 | Panasonic DVD & Blu-Ray Players
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | DVD & Blu-Ray Players
DVD not reading but spinning
Are you using +R discs(not the -R)? Use Sony brand +R or try using a few +RW's and see if that corrects the problem.
Feb 23, 2008 | iLO DVD Recorder DVDR05
LG DBRH197H DVD Player/HDD Recorder Logo
411 people viewed this question
Top LG DVD & Blu-Ray Players Experts
Are you a LG DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
