There are so many possibilities... If you are SURE that the lamp is good (did you take it out & look at it?) Easiest: When you turn on the tv, do you hear a 'whirring' sound coming from the back? If you do, is it a 'smooth' sound or is it rough, scratch, & noisy?. If it is smooth, or if there is no sound, next place to check is the power supply. If it is rough & noisy, it is a bad color wheel. Unless you REALLY know what you are doing, anything other than a lamp replacement should be left to a professional repair person.
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
