i burnt a torrent file (avi file ) and i burnt to a disc dvd-r 16x and when i put in player plaer says no disc in so am i using wrong disc type or wrong file type
Most AVI files from the torrent network use codecs to compress the size of the file you are downloading, and most DVD players only support the basic DIVX codec. A way to get around this issue is to use Nero software on your PC to burn a Video DVD. Selecting this option will make the program decipher the data and write it to the dvd as a compatible format with your standard DVD player.
when I power it up or open and close the door it starts making a clicking noise and just says...
(More)
when I power it up or open and close the door it starts making a clicking noise and just says loading on t.v. but wont play,,,, apex model # 1110w
burnt some dvds a while ago and they use to play fine on my apex, but for some reason now I just get...
(More)
burnt some dvds a while ago and they use to play fine on my apex, but for some reason now I just get unknown disc
Hi all, I have an Apex Digital AD-1110WM. The symtoms are: The disc loads, it speeds up, then it...
(More)
Hi all, I have an Apex Digital AD-1110WM. The symtoms are: The disc loads, it speeds up, then it slows down, speeds up again, then it displays: UNKNOWN DISC. This is with a factory disc. When I insert a home made movie, it keeps tracking back and forth and sounds like it has stripped gears. Again, it displays plays:UNKNOWN DISC. All esle seems to be functioning properly, including the Apex logo on screen and displays: NO DISC, when I don't load a disc into the unit. Can someone please let me know if this sounds familiar? Maybe someone has experienced the same symptoms and would be kind enough to share it with me. Thanks for your help in advance.
