Question about Motorola Mobility H300 Wireless Headset
Why wont my bluetooth h300 turn oni changed the battery because i thought that was the problem but noe its like theres no power it just wont turn on no blinking lights or anything
    Problem Solver:
  • 5 Answers
Did you hold the call button down for more than a few seconds?
Check the manual out to make sure your doing the correct process.
Link- http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
Posted on Jan 14, 2010
Can you set the H300 to pairing mode
startingwith the power off push and hold the call button while the head set turns on....then continue holding the call button until the light turns blue that has enabled the pairing mode now the pin code for all h300 model bluetooth device is 0000..i hope this helps
Feb 01, 2011 | Motorola Mobility H300 Wireless Headset
Bluetooth wont turn on
Check the manual to make sure your setting up correctly.
Oct 11, 2009 | Motorola Mobility H300 Wireless Headset
Power on motorola h300 bluetooth
Use this manual for the bluetooth to tell you how.
Oct 05, 2009 | Motorola Mobility H300 Wireless Headset
Need a pass key for a motorola h300 in order to pair it with a samsung sphm 540
the pass key is 0000
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
Jan 22, 2009 | Motorola Mobility H300 Wireless Headset
Pass key
pass key 0000
for more clear instructions go here
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
Jan 13, 2009 | Motorola Mobility H300 Wireless Headset
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Connection problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H300 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Nov 19, 2008 | Motorola Mobility H300 Wireless Headset
Bluetooth with samsung sph-640
Moto H300 should be "0000"
Jul 29, 2008 | Samsung SPH-a460
No Power
Radio interference from a nearby bluetooth-capable device that's paired is the culprit. Pair your bluetooth and your phone in the basement of your home, if your home does not have metallic walls and doors..
Apr 21, 2008 | Motorola Mobility H300 Wireless Headset
NEED TO RESET
try pairing and entering the code 0000
Dec 27, 2007 | Motorola Mobility H300 Wireless Headset
Motorola Mobility H300 Wireless Headset Logo
219 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
