Question about Nokia 6500 Slide Cellular Phone
Hi my nokia 6500 back cover doet not perfectly fit on the phone when i try to do so
    President:
  • 1,952 Answers
Try to contact nokia care service center
Posted on Jul 16, 2009
  • mohammed marika thambi
    mohammed marika thambi Jul 16, 2009
    Nokia released 5 versions of
    this back cover, due to the memory card problems, there have also been
    quite a few software updates due to stability issues, try backing up
    everything and then using the Nokia software updater available under
    Support on the Nokia website
    - Is it saying that message when the back cover is removed???
    http://www.nokia.co.uk/get-support-and-s...
    The
    first thing the Nokia service centre would do is upgrade the firmware,
    if the above doesnt work please do backup everything you have on the
    phone using Nokia PC Suite available at
My nokia 6500 slide can not read the memory card, please help..
If the memory card is OK.then check the back cover,generally this phone has a pin on the back cover to press the mmc leap switch.Anyway You can try, first remove the back cover, open Gallery in your phone and press the switch which is located near the mmc slot.If there is no internal damage Memory will be shown when you press the leap switch.If mmc is shown put a piece of paper of something to block.Otherwise you need to contact mobile repairing shop.Good luck
Feb 24, 2012 | Nokia 6500 Slide Cellular Phone
Hi please tell me how to unlock nokia 6500 slide
you can try to check if theres any updated software/firmware for your 6500. you can check that from this website:
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
then enter the code which is located at the back of your phone.
you can check the your current firmware by typing *#0000# from the standby screen
NOTE: PLEASE MAKE SURE TO BACK UP EVERYTHING BEFORE UPGRADING YOUR SOFTWARE/FIRMWARE
if it shows that theres a latest software version than the current version of your phone then upgrade your software using Nokia PC Suite. then it will reset your security code and settings.
Aug 22, 2010 | Nokia 6500 Slide Cellular Phone
Foutcode 6500 pixma mp800
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .........
Jan 08, 2010 | Canon Pixma MP800 All-In-One InkJet...
My nokia 6500 i turned off and was work fine before,now
its a software problem. I think the software files are corrupt and that's why the phone cannot boot.
The phone needs to be reformatted for it to work properly again. The process is called Flashing.
That's the only way your phone could be revived.
Take care.
Jan 02, 2010 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide - the other person can't hear me
hi thanks for using fixya!
Perhaps the error is in the mouth piece of your unit. If you have a problem with the hardware, better send your phone to a Nokia Care Center to further check the hardware error.
If you need further assistance, let me know!
Please rate me positively! thanks!
Jun 18, 2009 | Nokia 6500 Slide Cellular Phone
I cannot open Gallery on my nokia 6500
Check the back cover is on securely...
The back cover on these has a trigger mechanism that goes into the phone to make the memory card work, the back cover being on wrong causes the memory card to go off or on and off...
May 08, 2009 | Nokia 6500 Slide Cellular Phone
Lost all tones and wallpapers
format the phone you will get all the tones which the nokia company givews while manufacture
Apr 09, 2009 | Nokia 6500 Slide Cellular Phone
Getting battery cover off a nokia 6500
Using your thumbs, trying sliding the back cover toward the top of your handset.The back cover should release from hinges and you can use your fingers, nails or small tool to lift the battery cover off. With this device specifically, the thumb feature is needed.
Hope this helps!
Mar 19, 2009 | Nokia 6500 Slide Cellular Phone
My nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
Feb 18, 2009 | Nokia 6500 Slide Cellular Phone
PROBLEM FOR NOKIA 6500 SLIDE
THE PROBLES IS THE BACK COVER OF THE CELL PHONE IT LOSES. SO THE MEMORY DISCONNECT THATS WHY IT GOES BACK TO PHONE MEMORY. THE DESIGN OF NOKIA 6500S-1 NEED THE BACK COVER TO RUN AND DETECT THE SD MEMORY.
Feb 17, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 Slide Cellular Phone Logo
176 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
