Question about Microsoft Windows Vista Home Basic Edition for PC
Under control panel add and remove, i have a
Under control panel add and remove, i have a large amount of files that i removed previously, that continue to show up and i cannot get off. how can i get rid of them permanently.
    President:
  • 1,383 Answers
Download revo uninstaller from this link
then install in computer then run it then sleect program which you want to uninstall remove also registery key it ask you for that.
then it uninstall from your computer.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Let me know if you have any confusion.
Thanks.
Posted on Jul 16, 2009
Pop ups and its slow
Well it can be many reasons why it's slow, but I have a few things you could do that may help.
First make sure you have security for your system. Microsoft Security Essentials is free. It can guard your system from viruses, spyware, and other malicious software. Below is some of my notes from college on speeding up your computer. I hope this helps.
Indexing service is a little program that uses a large amount of RAM. The program indexes and list files that are on your computer so when you do a search for things on your computer it can find it faster by scanning the index list. You don't need this service so to disable it.
Go to start
settings
control panel
add/remove programs
add/remove windows components
uncheck the index services
click next
Optimize display settings
visual items can waste system resources
to optimize:
start
settings
control settings
control panel
system
advanced tab
in the performance tab click settings
leave only the following ticked
show shadows under menus
show shadows under mouse pointer
show translucent selection rectangle
used drop shadows for icons labels on the desktop
use visual styles on windows and buttons
Speedup folder browser
when you open mycomputer the slight delay is because win xp searches for network files and printers every time you open windows explorer
mycomputer
tools folder options
view tab
uncheck the automatically search for network folders and printers check box
click apply
click ok
reboot comp
Remove the Desktop Picture
Your desktop background consumes a fair amount of memory and can slow the loading time of your system. Removing it will improve performance.
Right click on Desktop and select Properties
Select the Desktop tab
In the Background window select None
Click Ok
Remove Fonts for Speed
Fonts, especially TrueType fonts, use quite a bit of system resources. For optimal performance, trim your fonts down to just those that you need to use on a daily basis and fonts that applications may require.
Open Control Panel
Open Fonts folder
Move fonts you don't need to a temporary directory (e.g. C:FONTBKUP?) just in case you need or want to bring a few of them back. The more fonts you uninstall, the more system resources you will gain.
Free up disk space
The Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
Remove temporary Internet files.
Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
Empty the Recycle Bin.
Remove Windows temporary files such as error reports.
Remove optional Windows components that you don't use.
Remove installed programs that you no longer use.
Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
Speed up access to data
Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.
When to run Disk Defragmenter
In addition to running Disk Defragmenter at regular intervals-monthly is optimal-there are other times you should run it too, such as when:
You add a large number of files.
Your free disk space totals 15 percent or less.
You install new programs or a new version of Windows.
Feb 11, 2014 | HP Computers & Internet
I want to remove wgs from my desktop
there are a few ways to do this.
Either upgrade to a newer addition and it will automatically overwrite the previous data.
Go to control panel, and add/remove programs and remove it.
Go to start menu, run, type regedit, go to HKEY_CURRENT_USER, and go to software tab and expand it. Find the file and delete it. Also do this under the HKEY_LOCAL_MACHINE and go under software and find the file and delete it.
Go to start menu, search, once the file is found, delete it.
Nov 08, 2010 | Microsoft Office 2003 Basic Edition...
Downloadable drivers for VN4100pc handheld that works on 32 bit
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows 7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 10, 2010 | Olympus VN-4100PC Digital Voice Recorder
I need Digital Wave Player soft to work with VN-480PC
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
Mar 06, 2010 | Olympus VN-4100PC Digital Voice Recorder
I have just changed my laptop with windows 7 but i think i need a driver to update my olympus vn-4100pc is there one
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
Feb 21, 2010 | Olympus VN-4100PC Digital Voice Recorder
Still need driver for Olumpus VN-4100pc for xp
1. Open the 'Add / Remove Programs' (Pre-Vista) OR 'Programs and Features' (Vista) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista) OR Programs and Features (Vista).
SAVE to the desktop
SAVE to the desktop
Feb 19, 2010 | Olympus VN-4100PC Digital Voice Recorder
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
Scanner problems
This worked for me. You want to start fresh so delete your HP printer in "Printers and Faxes". Also delete any HP software that loaded in Control Panel "Add and Remove Programs". Next in Control Panel under "Add and Remove Programs", the "Add and Remove Windows Components" TAB, check mark the file to add called "Other Network File and Print Services". After clicking next, the extra print files will load. Reload your software/ HP drivers and it should be fine.
Jul 05, 2009 | HP Office Equipment & Supplies
I get this error everytime I try and use IE I can't use IE it wont launch runtime error! program:c:\program files\Internet Explorer\iexplore.exe this application has requested the runtime to...
you can try to re-install IE, go to control panel then open Add/Remove programs, on the left side of the Add/Remove programs applet click Add/Remove windows components, under Components look for internet explorer then uncheck it then click next, IE will now be uninstalled. Then reinstall it, just like previous process on Add/Remove windows components put a check on internet explorer then click next.
If this wont solve the problem, you can try a third party browser like firefox, download firefox on this site: http://www.mozilla.com/en-US/firefox/, after downloading firefox just double-click it then just follow the installation.
Jul 23, 2008 | Computers & Internet
Iexloprer prob
Start/Settings/Control Panel/Add-Remove Programs/Windows Setup – remove ICS. Do not reboot.
Click Start, click Run, type Regedit (hit enter)
HKEY_LOCAL_MACHINE,System,CurrentControlSet,Services --
Remove ICSharing key
Under Class, noted number of folders under NETTRANS key.
Don’t close, just go to next step.
Under Network properties:
Add protocol called NETBEUI
Remove all instances of TCP/IP
Click OK DO NOT reboot.
Back to Regedit, press F5 to refresh the screen. Remove all folders under NETTRANS key that WERE there before. Do not remove the new keys. They might be at the end, or in the middle. Don’t remove the new NETBEUI folders.
Back in Network properties, add the TCP/IP protocol. Be sure that File and Printer Sharing is not present (this is a must), and delete the NETBEUI protocols.
Start/Settings/Control Panel/Add-Remove Programs/Windows Setup – Communications – select ICS. Click OK, Click OK.
ICS should run perfectly. Then open network properties and add File and Printer sharing.
May 10, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Windows Vista Home Basic Edition for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
