Question about Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe
I have an Iomega MiniMax Hard Drive that was previously formatted for a Mac. It is supposed to be 500gb but when I format it for my PC it only shows about 234gb in the primary partition. How can I regain the other half of the space it should have?
    President:
  • 1,383 Answers
Connect your harddisk to computer.
Then right click on my computer icon then click on "Manage"
then click on "Disk Management"
then find your removable device then you find unpartitioned space create new partition .then check.
Also check jumper settings of your harddisk.
It should not be on 16 bit or 32 bit in hardisk.
Posted on Jul 16, 2009
I just purchased an iomega ego /500gb and I'm having a problem formatting it by following their instructions. I just want to be able to plug it in and save my music. My mac doesn't even recognize it once...
You will need to format the drive to work with you Mac.
1. Open Disk Utility
2. Select Applications > Utilities > Disk Utility
3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon.
NOTE: For devices with 2 or more hard drives, please review the configuration settings to determine which volume type works best for you.
4. Select the Partition tab.
5. Change Volume Scheme from Current to 1 Partition.
6. Select the format type from the Format drop-down menu.
Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
7. Click on the Options button.
8. Select the type of partition you want to use:
GUID Partition Table - for boot ability on Intel-based Macs
Apple Partition Map - for boot ability on PowerPC-based Macs
Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type.
CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC).
9. Click OK.
10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 21, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Could not find pretige iomega icon on my computer
format the harddrive as MS-Dos to be able to use it on Mac and PC.
Apr 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Sep 17, 2009 | Iomega (33090) 250 GB Hard Drive
Iomega 500GB data corrupted
The boot info is bad. If there is info that is needed you will have to use a recovery program like getdataback fat 32 and getdatabackntfs
Aug 02, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
My mac cant see my minimax 500GB, it powers on and spins up, but i cant see it on my desktop. I'm using the firewire cable.
The above answer is wrong. All MiniMax drive are formatted for Macs out of the box (that why they are shaped exactly the same as a mac Mini).
Try connecting with a USB lead to see if that works.
These units are generally very good (i've installed about a dozen in the last year) but I have known some be DOA (I've only had one). Do other externals work in your FW port? If they do, plug them into one of the other ports on the MiniMax and see if they still work.
There is always a chance that your FW port is faulty - they have been known to need resetting (you'll have to google that as I can't remember the exact procedure - I think a quick way is to disconnect everything from the mac - yes everything! and leave the mac sitting naked and forlorn for about 20 minutes, then reconnect everything including your minimax and power up the mac. With luck it should come on and mount. Let us know what happens.
Jul 15, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega
Yes. The MiniMax is designed to match the MacMini from Apple and comes formatted out of the box to work with a Mac. (One of the few drives that is!)
I think Iomega supply various Windows drivers on the CD
Apr 09, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Open Questions:
See all Iomega MiniMax Desktop - Hard drive - 500 GB - Questions
Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe Logo
219 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
