Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 Rear Video Projector Convergence Problem
I have had this television for almost 5 years; the manufactured date was July 2003. One day, the image on the television was all screwed up:
  • There is a concave image(middle part of the picture bending in and the outer ends bending out)
  • The red-blue-green colors were separated so it looked like 3 images at once
It's all blurry with color messes everywhere. There are red and green lines at the ends. It also has the same problem with my DVD/VCR.
Convergence menu and flash-focus doesn't work - otherwise the t.v works perfectly fine.
From all the other questions, I think the problem is something about replacing convergence amps, whatever that is. But I'm not circuitry-savvy so I don't know what in the world I have to do to fix it. What items do I need, where can I get it, how much will it cost, how will I fix it and is it advisable for someone to look at it or will I be able to do it myself? (I'm handy at fixing things) Is there anyone willing to share their time? Thanks a bunch.
  • 20 more comments
  • bentay Nov 18, 2007
    im also having a convergence issue. No adjustmenst work. What gives? What might i need and where is it on the tv. What does it look like??Please Help!!!
    Thanks
  • goober1 Dec 31, 2007
    SCREEN IS BOWED AT BOTH ENDS AND SCREEN HAS THREE COLORS RED, BLUE AND GREEN IN THREE SEPARATE PICTURES ON THE SCREEN.TRIED THE FLASH FOCUS BUT IT DID NOT HELP. VOLUME WORKS GREAT.
  • jerry77 Dec 31, 2007
    I have the same issues with my tv. The top and bottom are moving toward the center and both ends have a different colord line from top to bottom. Also all text is like reading triple in different colors. Happened over night with no warning. What gives? no adjustments helped.
  • Anonymous Jan 08, 2008
    Mi televisor
  • Anonymous Jan 11, 2008
    Hey - I have exact same problem...picture looks concave and there are three distinct images in red, green & blue. TV is less than 5 years old and other than the 3-D looking picture, everything else works fine. Haven't gotten a quote on getting it fixed yet.
  • jackedtv Mar 08, 2008
    I have the same bowed convergence problem. The one guy went to the expense to fix the ic's and 5 amp fuse, but now still doesnt work so someone is telling him the convergence output resistors are blown... all this is greek. help!
  • Anonymous Mar 11, 2008
    the picture is bowed and the color is distorted
  • brokes Mar 11, 2008
    pictured is bowed color distoted
  • rinkrat19 May 04, 2008
    The picture has curved lines in the upper left corner and red, and green images as well as the original picture. The TV is about 4 years old.
  • Virgil467 May 22, 2008
    I turned the tv on and the writing was in yellow, red and blue. The picture looks curved inward. The images in different colors are almost on top of each other. What is causing this? It worked fine a couple of hours before. ow do I get it fixed?
    Thank you.
  • AsllanPasha May 23, 2008
    Hi fellas,
    I seem to have the same problem with my HDTV; I've bought it new, and have owned it for about the same amount of time as the other people reporting this issue. What do you recommand, do you have the parts/part numbers or know how to order it and how much it might cost to repair it.
    Please advise,
    Best Regards,
  • fio1 May 24, 2008
    I have had this television for almost 4.5 years; the manufactured date was JUly 2003. One day, the image on the television was all screwed up:
  • edthetvowner May 31, 2008
    Same thing here. Red/green seperation in the picure. I have had my tv for 4 years. HOw do I repair it?
  • fdelos Jun 24, 2008
    Flash focus is the only thing That I have done.
  • Anonymous Jul 26, 2008
    color are seperated an bent
  • Anonymous Aug 14, 2008
    Same problem as above.
    Bought 5 yrs ago.
    the picture in the middle bending in and outer bending out
    can see 3 colors seperately at the bottom
  • Anonymous Oct 01, 2008
    Convergence Problem
  • Anonymous Nov 15, 2008
    Same problem and owned for 4 to 5 years.  Anyone actually got it fixed or should we just bite the bullet and buy a new set?  Scanning the web, it seems this could be a $1,000 job.
  • colombicho Dec 11, 2008
    convergence can not be auto or manual adjusted. the video is red and out of focus
  • bb_banking Dec 19, 2008
    I too have the problem. My set is about 4 years old and was informed that the problem is a convergence circuit DNR needs replaced. Live in ohio and was quoted $335-$375 to fix. Wouldn't you know that its the right in the middle of my price point to purchase another. Rest assured , Sony will not in my lifetime be another tv product that I purchase. - Jim in OHIO
  • Anonymous Dec 19, 2008
    Same problem as above, BOUGHT IN DEC 2003
  • Anonymous Dec 22, 2008
    I had the same problem as above. I purchased this TV in October 2003.
  • 42 Answers
Subject
Video bowed in, convergence out, PS5001
Symptoms / Customer Description
Video bowed in and convergence is out.
[Primary Symptom Code: 1436 ]
Solution
Found PS5001 on G board was open.
HQ Comments: Could be cold solder joint on one of the STK IC's on the D Board. They run hot and the solder connection might have broken down causing intermittent condition which could have opened the fuse on the
-22v line.
You can find the full repair manual Here!
Posted on Nov 16, 2008
Need help
Posted on Nov 18, 2008
How do I replace the convergence ICs
Posted on Jan 13, 2008
    Sergeant:
    Champion:
  • 346 Answers
Replace the convergence ICs
Posted on Nov 24, 2007
My sony tv model # KP-46WT510 the picture bows to the middle i tried fixing the convergence and it does nothing what else should i try
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Aug 28, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Where is the convergence chip located
Convergence out ICsare located on D Board of Sony KP-46WT510
These are 2 big ICs of black color mounted on silver heat sink.
Check out location of D board in TV in below exploded view...
Aug 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Rear Video Projector model # KP-46WT510 and it started acting up. It is a double picture when we try to watch TV. Can this be easily fixed?
Unfortunately it is a job that will require an experienced TV technician,
You have 2 large 18 pin ICs called convergence amplifiers who's job is to insure beam alignment of the three picture tubes in your TV set (Red, Green & Blue). One of the 2 chips have shorted and more than likely cause damage to the 2nd one as well. This involves removing the board where the ICs are mounted then rmoving the ICs by a process called desoldering & resoldering during the replacement process. They are not a plug in Ics.
Hope this helps.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem
you need to replace the convergence ICs, pico fusses and possibly a couple of the feed resistors. you can get the kit for your model at the following link which contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Jan 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
1,392 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
