Where do we start? We purchased a new battery for our quad. It worked fine but now the electric start won't work. It will kick start and the starter clicks but won't actually start.
Thank you! One other question, do you know where the relay and starter fuses are located?Thank you! One other question, do you know where the relay and starter fuses are located?
The Starter has no fuse .The user manual should show the fuse lay out as they differ on each model.The Starter has no fuse .The user manual should show the fuse lay out as they differ on each model.
You can't post conmments that contain an email address.
Hey Michele,, if the original battery lasted this long.. you are lucky,, just replace it. >>> Always use the exact replacement battery<<<<... your quad is designed to take the exact size and amperage rating,, trying to change this is inviting too much trouble,, When you get a new battery,, it will be charged unless you purchase one online that comes with the acid pack,, EITHER WAY - put the battery on the trickle charger for 48 - 72 hours BEFORE you use it.. This will extend the life of the battery a bunch and make it a stronger battery,, ..(this is from too many years of experience.)
just for fun, while you're cranking it put your hand over the intake of the carb completely covering it and see if your hand gets wet with gas. this might even start it too.
you do have an ignition or it wouldnt start and run, even with a push start, maybe you want to install a kick start, or an electric starter, either way, look up the maker of your quad on the internet, and check their different starting options
