Question about Fujitsu Siemens LifeBook E4010 Notebook
To startup, I have to press to On/Of button 2x or even more. Sometimes, the startup begins, but more and more, nothing happens. It seems that even the bios won't startup. This problem with 2 of these notebooks, Fujitsu E4010. Is this a known problem? And if so, can you describe this problem and is there a solution?
    President:
  • 1,383 Answers
Frist Rfix your battery and RAM memory.
then check if problem still remains then you have to reset bios setttings .
For that you have to open back side of laptop.
Then you find mother bord chip set.
Pull cmos cell from mother bord for 15 seconds then refix it then check.
you can refix Battery and RAM from back side there is 2 small plate RAM plate is up on battery plate.Let me know if you have any confusion .
Thanks.
Posted on Jul 16, 2009
Cannot start the netbook
Yoke, sometimes a recently installed application may be causing a problem. Try the following free or paid apps: 1. slim drivers 2. advanced uninstaller 3. advanced system care. These are great progs. and am sure will help you BUT be careful of actions you take.
Jan 05, 2014 | ASUSTeK COMPUTER ASUS Eee PC 1015PEM...
Problems burning a cd with Sonic DigitalMedia Plus v7, I am on an HP notebook running XP
Try different software. I use CDBunerXP with no problems. It's free. Just don't install any extras (add-on programs) they include.
You should let it burn with no other activity during the process.
Oct 16, 2012 | Computers & Internet
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
Hp f370 printer doesn't turn on
my hp f370 does not turn on anymore. checked the power supply adapter using a multimeter, the voltage are correct as per the label. when i press the ON button, nothing happens, not even a light will lit. what seems to be the problem?
thanks in advance.
Nov 10, 2009 | HP DeskJet F380 All-In-One Printer
I HAVE ACER ASPIRE 6930. STOP AT THE BEGINING LOGO
Try taking the system memory out and reseating it, the memory is located underneath the laptop behind a panel like this >>>>
Clean the contacts on the ram and reseat it then try to boot again.
Make sure you remove the battery and the AC power supply before you remove the ram cover.
Good luck
Jun 28, 2009 | IBM ThinkPad T30 2366 Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
Startup problem
This could be a corrupt bios or a low cmos battery, follow instructions. Take the right hand side panel off the pc. Look for a disc shaped 3V watch type battery and replace (Very cheap) Look on the motherboard and reset the bios at the 'JBAT1' terminal put jumper(little plastic cap) from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart pc and enter bios when prompted(or press F2 or DEL on startup) to set time and date, save settings and Exit bios. It should now boot ok.
Jan 25, 2007 | Systemax AOL Optimized PC (100607) PC...
Fujitsu Siemens LifeBook E4010 Notebook Logo
555 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
