Central air just stopped running, was running all day. I turned down the thermostat about an hour ago and I heard it come on. I noticed it wasn't running just a little while ago. Looked an the thermostat says it is 78 while the aircon is set for 72. It wont come back on I tried resting the thermostat and checking the breakers. I even switched the furnace off on the side. The furnace is about 30 years old...
  • 534 Answers
Possible you have a bad contactor switch.. Have a tech look at this since it is dangerous due to high voltage and age of unit
Good Luck
Dave
Posted on Jul 16, 2009
The fan on one my central heating and air unit won't come on? It was working fine when I went to bed at 1:30 in the morning and when I got up around 7:30 this morning it wasn't running anymore.My house has...
Running the equipment on 72 degrees would cause the compressor and fan to work harder on hot days. This will definitely place more strain on your capacitor. These capacitor problems usually happen on the hottest days. I would suspect the capacitor, not the fan. I'm an HVAC tech, so I would Check both with my multimeter
Aug 25, 2013 | Heating & Cooling
Whirlpool model WC260A-1A cannot find manual and central air conditioner will not turn on worked well 2 days ago.
Does the fan turn on when you have it set to cool? does the furnace still work? Does the fan auto, and on options still work?(for example when on its on, when auto, and neither the cool or heat functions should be running, the fan is off)? Basicly i'm asking your to test your thermostat right now.
Aug 04, 2013 | Whirlpool Central Ac Condenser-new...
RUUD AC cycles warm & cold 24/7
Hello Anna Sounds like the compressor is overheating and stoping on overload internally.Then it cools down restarts and runs into overload again.I would like to see the freon pressures when running.Could have a clog/restriction in piping.I dont like that you went thru a compressor already, the original installition is suspect.The original (1st) failure cause must be corrected.Check the TXV valve replace, filter/dryer look for a kinked pipe are ideas for overheating.Make sure condenser coil is free (ari flow)& clean also.
Jul 30, 2010 | Ruud UBHC Air Conditioner
Central A/C trouble in Las Vegas!
The contactor in the outdoor unit is stuck.You will need to replace the cooling contactor.I am sure it is wielded shut and thus will not turn off.
Sep 06, 2009 | Heating & Cooling
We do not know how to turn the whole house fan on. Does it work through the thermostat on the walll for the air- heat switch?
To turn on your whole house fan, got to you thermostat. Open the door and look for where it says fan, most will have a selector switch to select "auto" or "on". You want it "auto for it to work properly with your furnace and or central air. If you flip it to "on" it will run 24 hours a day none stop, warning this may shorten the life of your fan a little.
Jul 29, 2009 | Ventamatic Direct Drive Whole House Fan...
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Central Air Compressor Runs Constantly
Sounds like the contactor is stuck in the outside unit. Turn off the breaker or safety switch, remove the cover, and tap on the body of the contactor with a hammer handle or similar tool. If a click is heard you may have dislodged it and it may work for either a short time or indefinitely. (yeah ,I know that's kinda vague) Test it. If that doesn't clear it up, disconnect the thermostat wires just to make sure and re-test. If the compressor starts without the thermostat connected, you will need to replace the contactor. If you feel real handy, you could perhaps remove the cover, seperate the contacts with a screwdriver, dress the contacts with an emery board until smooth and shiny, and try again.
May 24, 2009 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
