Question about Samsung RS265LABP Side by Side Refrigerator
Freezer works fine--Fridge Side Not Cooling Properly
The freezer side works fine, but the fridge side has risen in temp. from 38 degrees to 50-55 degrees. We have tried the troubleshooting tips from the manual--resetting the temp./power cool button, etc. We have also tried cleaning the coils.
Any advice before we call a repairman?
Thanks!
  • Samsung Master
  • 4,654 Answers
I am sending you a link below to download the manual for your model. There are too many Q&A to do this here and on this page. The manual has some self diagnostic test you can do yourself through the control panel. These are very good refrigerators and they are backed by Maytag. The only problem is they are complex. You can try to find answers and if you have questions I will need to be contacted by email because Fixya has not been sending out anyones responses lately. They know about the problem. Sea Breeze
appliancepartsse@yahoo.com
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
Posted on Jul 16, 2009
Fridge is freezing....
The way you've stated your problem is confusing? The temperature is the freezer should be 5 degrees F or below, preferably at 0 degrees F. The refrigerator side should be anywhere from 34 - 38 degrees F, What exactly is the problem your having, fresh food not cooling but freezer works ok?
May 07, 2012 | Westinghouse Refrigerators
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
Side by side unit. no temperature control in freezer or fridge temperature of fridge is 60 degrees F on top. Freezer temp is 45 degrees. Bottom part of fridge is 28 degrees F.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 13, 2011 | Frigidaire PLHS267ZA Side by Side...
Fridge side works fine freezer side keeps running no matter were you set the temp -10 -20 degrees sounds like the fridge is running all the time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 06, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Refrigerator Model TFX22KRDA. The evaporator located in the freezer ices over and loses cooling capacity. When turned off and the ice is removed, the freezer and refrigerator both work fine for a few weeks...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | GE Refrigerators
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Running long time
hi thanks for the question. yes if that's the temp that you say 36 to 38 degrees is normal operating temp thanks the appliance doc
Sep 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS265LABP Side by Side Refrigerator Logo
742 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
