Question about Nokia 3110 Cellular Phone
To get packet data connection for nkia 3110 classic
WHENEVER I TRY TO START WEB THE ABOVE MESSAGE FLASHES?PLEASE HELP!
Whenever I try to use the web, it always say, packet data: packet data not available, check network services. What will I do?
Every service provider has different settings for internet access. You must contact the service provider /network that you use. They can send the settings via text and enable you SIM for data access. Be sure to ask about the billing
Let me know how it goes.
Sep 08, 2011 | Nokia 6120 classic Cellular Phone
How can i set my nokia 3110 paket data
set your packet data,follow this..
1.menu
2.setting
3.connectivity
4.packet data
5.packet data connection
6.select always online
i hope it will help you,thanks for trusting fixya
Jun 16, 2010 | Nokia 3110 Cellular Phone
PLEASE HELP ME WITH To get packet data connection for nkia 3110 classic
the code depends on which network u r usin......there s a different code for different networks.......it will easy if u contact ur customer care........they will activate it for u
Oct 28, 2009 | Nokia 3110 Cellular Phone
Subscribe to Packet data first error in Nokia 3110c for Aircel
just call the aircel cust care no and asskk them what is the minimum balanace required in the account or ask the cust care to get your call connected to the tech department and they will help you to manuallly set the settings.any clarification revert back please
Sep 09, 2009 | Nokia 3110 Cellular Phone
Subscribe to packet data first..
Here is what to do : In opera mini check what type of connection is been set . There are to types [HTTP , SOCKET] . Just try to switch between them and you'll solve the problem . For me [SOCKET] is always better , because [HTTP] takes long time to load a page . If that didn't solve the problem , then in the phone , go to SETTINGS and make sure that all applications are allowed to use your preferred access point as default for Applications .
your rating is very important for me , that's why I've helped you .
good luck .
May 11, 2009 | Nokia 6300 Cellular Phone
Nokia 3110 classic usb device malfunctioned
Please try connecting your phone to a different USB port other than the one which you use normally.
If the issue is the same then try connecting it to another PC if you still face the problem then it is a hardware issue.Either your phone or the USB cable is gone bad.So replace the USB cable first with a new one and then try connecting.If the issue is till the same then it is your phone and you will have to get it repaired or get it replaced if it is under warranty.
Feb 10, 2009 | Nokia 3230
Subcribe to packet data first
i cant suscribe to packet data
Nov 01, 2008 | Nokia 3110 Cellular Phone
Operamini & Email not working on nokia 3110 classic
Do the following steps:
1.Menu->Settings->Configuration->Personal Configuration Settings.
2.Options->Add New("Add New" directly if the folder is empty)
3.Choose "Access Point"
4.Account Name: anything(say Java)
5.Access Point Settings->
6.Data Bearer: Packet data
7.
Bearer Settings: gprsnorth.cellone.in
Network type: IPv4
Authentication Type: Normal
User name: ppp
Password: ppp123
8. Save these settings.
9. Come back to Personal Configuration Settings,
10. You will see a new access point named Java.
11. Options->Activate.
12. Voila! You are done! Now you can browse through the internet on any java application.
Feb 21, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
334 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
