Question about Zanussi ZWD12270 Front Load Washer / Dryer
My washer/dryer starts to dry and then stops after a short while with an error message - E10 (I think its a 10)
  • Ned Halaweh
    Ned Halaweh May 11, 2010
    Are you sure it's not an E3? that's a thermistor problem and will stop after a short while.
    President:
  • 1,776 Answers
I am not familiar with the Zanussi, but it sures sounds to me like maybe there is a problem with the high limit thermostat. It may be mounted on the side of the dryer. You can check it out with an ohm meter and you should get no resistance. If there is resistance, then the thermostat is bad and must be replaced. It is sensing high temps and is shutting down the machine. This is only a guess on my part, without looking at it. Sure hope it helps you. Good luck.
Posted on Jul 17, 2009
Tumble dry problem
Error 10 is a low water pressure alarm.Check that the drain tube is clear and in the drain pipe correctly.Does it take a long time to fill.There could be a problematic pressure switch or hose to this switch,or faulty Inlet valve or even a faulty Circuit Board.
Jul 14, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
What does E10 mean? is this an error
E10 means your machine has not filled to the correct water level (10 mins allowed) low water flow or blocked filter in the water valve . or faulty valve.check tap is turned on.
Jun 17, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
My aeg lavamat 16810 washer dryer won't dry. The error message is E10, meaning the water isn't going in. Water is running until the dryer kicks in, then the valve closes and it stops. The heater etc are...
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Oct 28, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Error E90
That happened to mine, and apparently it is the connection to the control panal at the front of the machine or the desplay unit (4 blue wires). Take the top off and wiggle them around or re-connect if any are loose. Mine worked for one wash and then started displaying E10........so i'm not amused and I think i may end up getting a hotpoint!
Nov 09, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZWD12270 Front Load Washer / Dryer Logo
235 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
