Ford mondeo mk4 x sport Fitted with keyless entry system,with push button start,rear door has been run in to,car will not start is there a reset a can do myself?
Hi,thanks for your response,I can't do that check,as ignition etc dose not come on when I press the brake pedal(auto)which it should do before you press power start button,I just get the dash message steering lock on!thats it!any thoughts??cheers JHi,thanks for your response,I can't do that check,as ignition etc dose not come on when I press the brake pedal(auto)which it should do before you press power start button,I just get the dash message steering lock on!thats it!any thoughts??cheers J
You can't post conmments that contain an email address.
It does indeed have keyless entry. It needs reprogramming when you get a new remote. Also if you disconnect the battery. Usually a local car alarm fitting shop, or an auto-electrician will do it. Plus of course a Ford dealership.
NO FOBS DETECTED
Refer to Keyless Entry System Description and Operation
Keyless Entry System Description and Operation - Passive
Passive keyless entry allows entry to a locked vehicle without pressing any buttons on the keyless entry transmitter. You must only have the transmitter with you. This passive system is also part of the vehicle starting system. It allows you to start and run the vehicle having only the transmitter as your key. The passive entry and starting system use low frequency antennas in 4 different areas on the vehicle to determine the location of the transmitter. When passively opening a locked door or the rear compartment lid, you must have a programmed transmitter with you in your pocket, purse, or briefcase. As a customer opens the door handle or presses rear compartment touch pad, the low frequency antenna sends out a challenge to the keyless entry transmitter. The transmitter must be in a one meter range of the door or rear compartment lid in order to receive the challenge. If the challenge is met, the transmitter will respond, allowing the door to be unlocked and opened. Passive entry allows you to operate the following features:
• Passive door unlock/unlatch
• Passive rear compartment lid release
• Illuminated entry lamps
• Vehicle starting
The keyless entry system has the following components:
• Keyless entry transmitters
• LH and RH door antennas (part of the door handle assembly)
• Rear compartment antenna
• Console passive antenna
• Console active antenna
• Instrument Panel Module (IPM)
• Rear Integration Module (RIM)
• Remote Control Door Lock Receiver (RCDLR)
• External RF Antenna (includes coax from RCDLR to back glass)
The RCDLR is a multi-function module which controls all the vehicles antennas for passive keyless entry functions. The RCDLR also acts as the receiver for active keyless entry and tire pressure monitoring (TPM) functions, as well as controlling all immobilizer functions.
The RCDLR's RF antenna is located in the back glass, and there is a coax cable connecting the glass antenna to the module located in the trunk.
Your best bet , take it to a qualified repair shop that has the factory Tech 2 scan tool or someother professional type scanner that can read • Rear Integration Module (RIM) DTC'S - diagnostic trouble codes .
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
So this answer is on the same topic of a 2005 Ford Focus keyless entry remote. There is no way to "reset" the code from the vehicle, however you can reprogram an existing or program a new keyless entry remote to your Ford Focus by using these simple instructions:
*** THERE ARE 2 POSSIBLE PROGRAMMING PROCEDURES. ***Procedure #1
Note: Obtain all remote transmitters for this vehicle.
Note: Do not depress the brake pedal during procedure.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
Within 20 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 4.
Within 20 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 3. For all other remotes.
Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Procedure #2
Note: Obtain all remote transmitters for this vehicle.1Fasten seat belts and close all doors.
Turn ignition from OFF to RUN 4 times within 6 seconds, with the 4th time ending in RUN. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
Turn ignition to OFF. Acoustic signal will sound and system warning lamp will illuminate to confirm programming mode.
Within 10 seconds, press and hold any button on the first keyless remote. Wait for acoustic sound and warning lamp to flash (confirming programming) then release button on remote. Wait 2 seconds but within 10 seconds repeat step 4. For all other remotes. If you only have one remote then continue to step 5.
Turn ignition to Crank or wait 10 seconds to end programming mode.
How to find the Security Keyless Keypad Code on the 1995-2001 Ford
Explorer or Mountaineer and how to use the Keypad functions. The factory
code is also printed on a label which is installed on the Remote
Anti-theft Personality (RAP) Module. This is the module that controls
the keyless entry system. It is
located in the left rear quarter behind the removable panel (see photo).
You will need to turn the two thumb screws counter clockwise and take
the plastic panel off to be able to see the unit. A flashlight may be
helpful in seeing the code. You are looking for the module and the 5
digit code on it like the one shown below.
Now that you’ve got the code I’ll tell you how to use the Keyless entry
and set-up your own code.Make sure when pressing the controls on the keyless entry keypad you press the
middle of the buttons to ensure good contact with the controls.
I have ford mondeo ghia 2002.
when i press the button on the remote-key, I can lock and unlock the powerlock (in the door).
When I press the button un the door, not all doors are locked.
