Question about Singer 3116 Simple
Thread's bunch-up lower fabric
Makes clonking sounds, it rams.
  • deannberndt Jul 16, 2009
    is there a recall on the singer simple 3116?
  • 3 Answers
Make sure your bobbin is in proper and secure, it should click when you put it in. Also try putting a new needle in. Clanking noises are sometimes a bent needle.
Posted on Jul 22, 2009
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
The bobbin thread is bunching up
hi Lois.
this is all i could find out.
Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turn.
or try this link.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
or this one,
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little window might open up in the middle of the page just close the little window down.
or this.
The bobbin thread is bunching up Google Search
Dec 12, 2017 | Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
Feb 06, 2016 | Consew Sewing Machines
Cotton is loose/looping under material?
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
When i run a straight stitch, the top of the fabric looks well sewn; the thread on the bottom of the fabric, however, bunches up-it looks nothing like the top stitch.
Is it really the bobbin thread that is bunching under the fabric, or is it really the top thread that is creating loops and "bird nests" under the fabric???
Rethread your upper thread. BEFORE you thread the upper thread, be sure to RAISE the presser foot. This releases the upper thread tension disks so the thread is firmly seated in the tension disk.
If it continues to be a problem, then the upper tension needs to be tightened. Adjust slightly, then test. Repeat until the upper and lower threads meet in the middle of the fabric.
Sep 24, 2015 | Sewing Machines
The thread bunches under fabric when sewing on leather
WHEN YOU FIRST THREAD LEAVE THE FOOT UP AND PAY ATTENTION IF YOU ARE GETTING A SNAG WHILE YOU ARE THREADING. IF YOU ARE THEN FIND OUT WHERE THE SNAG IS AND CORRECT IT. NOW, LOWER THE UPPER FOOT PRESSURE. THIS MUST BE LOWER BECAUSE THE FABRIC IS SO MUCH MORE THICK. IF IT IS STILL A PROBLEM TAKE NOTICE IF THE BUNCH IS ON BOTTOM OR ON TOP. MORE ON TOP THEN LOWER TENSION. IF THE BUNCH IS ON BOTTOM THEN TIGHTEN THE TOP. START YOUR TENSION ON TOP WITH THREE. THE BOTTOM NEEDS TO BE CHECKED FOR PROPER TENSION. THE BOBBIN SHOULD JUST HANG FROM YOUR FINGER. IF YOU BOB YOUR FINGER IT SHOULD BEGIN TO EXTEND JUST A SMALL AMOUNT. JUST REMEMBER THE THREAD IS THICKER AND MUST BE ADJUSTED BECAUSE OF THIS.
Jan 10, 2014 | Husqvarna Husky 145
The lower stitch (under the fabric) is using too much thread
Check everywhere to get lint plugs out of the way and change your needle. Make sure it's in correctly. And, make sure you're threading correctly...don't forget the take-up hook.
Apr 06, 2010 | Brother LS-2125 Mechanical Sewing Machine
The tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
M machine stopped working properly. The lower thread is bunching, knotting and the fabric is being pulled into the bobbin compartment. The machine also makes loud noise. thanks
bunching lower thread is actually the upper thread not having enough tension due to mis-threading or wrong tension setting
Jul 02, 2009 | Sewing Machines
Pulling on top thread bunches my fabric
Either the top tension is too tight or the lower tension is too loose.
sewman7
Mar 03, 2009 | Necchi 4595 Mechanical Sewing Machine
Singer 3116 Simple Logo
234 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
