Question about Dell Inspiron 1300 Notebook
What is the cause for this issues - Dell Inspiron 1300 Notebook
  • Mixplyxit Tigerbait May 11, 2010
    Sorry, you need to tell us exactly what the issue is.
  • Ben Morris
    Ben Morris May 11, 2010
    Please tell me the issues so I can issue you further.
    Problem Solver:
  • 10 Answers
What issues?
Posted on Jul 16, 2009
Can you fix a Transtherm wine cooler Manor Prestige. It is not cooling.
Not cooling issues in cooling devices has, generally, four causes
lost refrigerant
compresor damaged
thermostat issues
Fan issues
First I would check if the fan is working. If that is the cause, they are cheap and is a DIY job
For other issues, would suggest to have it diagnosed by a repair facility
May 19, 2017 | Furniture
I have an 03 GMC envoy sle 4x4. Trans fluid is overfilled. Can that b the cause of the slight slip in the tranny and also why my 4x4 isn't engaging?
Over filling can cause foaming of the fluid which could cause the slipping but it might not be the issue in your case and it is doubtful that is causing the 4 wheel drive issue.
Mar 06, 2016 | GMC Cars & Trucks
Can a bad deferential cause steering issue on 2002 envoy
I am assuming your mechanic was refering to the front differential and your vehicle is 4x4. If the vehicle is in 4x4 all the time you may notice a " hopping " feeling on corners from the front wheels. Otherwise, the differential should not cause steering issues. What type of problem is the vehicle experiencing that concerns you and would lead your mechanic to assess a bad diff?
Jan 20, 2016 | 2002 GMC Envoy
Steering wheel slightly hard while turning my car
The two systems in question are not related, so you have two issues to deal with. The power steering issue could be as simple as a glazed or loose drive belt. When you turn the wheel, the power steering pump puts additional load on its pulley. If the belt is glazed or loose, it can slip momentarily and cause stiffness in the steering. Low or contaminated power steering fluid can also cause this. Moisture in the fluid will cause problems since water compresses differently than hydraulic fluids. As far as the transmission is concerned, there are a lot of things that can cause late shifting, from vacuum issues to solenoids, to fluid quality and level.
Nov 22, 2015 | 2002 Nissan Pathfinder
Samsung how to
uninstall the latest touchpad driver.. I.E. rollback the driver.. I have seen this issue with other touch screens and its usually just a driver issue that is causing it.
Jan 13, 2014 | Samsung Series 5 Ultrabook Laptop
Check engine light stays on. Had code cleared 3 times and when I drive a block it comes back on. When it starts the engine surges on its own and sometimes quits.
Perhaps you need to remember that the engine light is a victum and not a cause. Clearing the codes does not address the issue that caused it to come on.
Pull the error code and follow that indication. REMEMBER that codes are a CLUE and not necessarily the cause. For example, an intake leak will cause misfiring and that makes high hydrocarbons, and that may cause an oxygen sensor error, but the sensor being out of range is NOT the issue, but the result of the issue....
Follow the indications from the error codes. Reset, as you now know, does nothing.
Mar 17, 2011 | Isuzu Rodeo Cars & Trucks
Clear code for engine light
The code clearing happens via two things> first, resolve the issue causing the error code. The code will come back if you do not resolve the issue. you can clear the codes by using a code reader, but it woudl likely reappear. Fix the issue causing the error code.
Remember, the code is a clue, not always the issue.
Mar 02, 2011 | 2004 Mitsubishi Endeavor
Xbox 360 repair 3 red lights
The 3 red lights issue is known as the red ring of death(or RROD)
This is caused by the x clamps used to hold down the processor.
The x clamps cause to much pressure which causes the xbox 360 to think it is over heating. Microsoft has issues a extended warranty for RROD issue. You can reach Microsoft by calling 1800 my xbox. The link below is to a Youtube video walk through on how to resolve the issue.
http://www.youtube.com/watch?v=fuIl0kGf7dM
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console - Black
Gives an error code lr
The “Lr” = Locked Rotor: The machine has repeatedly tried to turn the motor.
I have seen this issue caused by a failed motor. I have seen a bad Control Board cause this issue and a bad Motor Controller cause this issue.
If the Lr error code happened in the Spin Cycle of the wash cycle it could be caused by seized Outer Tub bearings.
Without a known good Control Board and Motor Control board this could be difficult to troubleshoot.
Here is a link for the FAV6800A/FAV9800A Service Manual
May 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Dell Inspiron 1300 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
