Question about Kenwood Heating & Cooling
I have aone and half ton split air conditioner and it keeps showing on display "F 8".....what does that mean....
Dear sir, may i know 0.5 ton how much load will take????????????????????
Posted on Mar 18, 2011
I have 1.5 ton split air-conditioner, so tell me that what size of copper tube will be installed in liquid line and suction line?
You should be able to measure the evap coil tube size or at condenser tube size where the tubing connect. But, standard size should be a 5/8 suction and 3/8 liquid line.
Aug 07, 2015 | Heating & Cooling
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
May 06, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
What is and how is find out cfm for 5ton air conditioner
12000 BTU is 1 ton
300 - 350 CFM in 1 ton depends on mfg.
Cfm and Tonnage of Refrigerent is are different units, then how these two units can be compared
Cfm means air flow per cubic meter per hour.
Dec 14, 2010 | Cfm Daikin R410a Split System Air...
What is the capacity of this A/C
The 36 means it is a 3 ton. One ton of cooling is 12,000 BTU's. 3x12 = 36, Tons = 3. Dang I just did algebra. Now if I can just figure if a hen and a half lays an egg and a half in a day and a half....
Jun 30, 2009 | Carrier 38CKC036 Air Conditioner
Split System Air Conditioner Model sn:QC136AUP(QC136EXU)107034-73 What six=ze is it ? what Kw?
Enter the name of the unit into your browser. It will ask for a model #. Enter that. All the info you need should be displayed. (I can tell by the model# your unit is 3 ton. Rule of thumb; 10 amps/ton Therefore 6.2 KW)
Ray
Nov 11, 2008 | DeLonghi Heating & Cooling
Heating & Cooling Logo
385 people viewed this question
Top Kenwood Heating & Cooling Experts
john h
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
