Question about Linksys EtherFast Cable/DSL Router
Missing The Power Adaptor for the Mod. BEFSR81B
Hello, I’ll appreciate if you can tell me the specifications of the power adaptor for the Linksys (EtherFast Cable/DSL Router), Mod. BEFSR81B
??-VDC, ??-Amp
Thanks in advance I really appreciate your help.
Salvador
    President:
  • 623 Answers
HI Salvador, the specs for the power supply of the BEFSR81 are:
Voltage: 5V DC
Ampere: 3A
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 16, 2009
Hello what kind of voltage use the power adapater?
The power adaptor has normally two voltages.
One is primary (Input) which is 110V AC in USA. 220V in UK and others.There are now a days Adaptors which accept both 220V and 110V. However the Adaptor pin will differ. It will be Flat pins for 110V and Round pins for 220V.
The other voltage is the Output which is fed to the Equipment and is Equipment specific. It can be 18V to 5.2 Volt DC. It varies equipment to equipment.. If a wrong Adaptor with output Voltage not matching with equipment requirement is selected, it may damage the equipment. Be careful.
May 21, 2015 | Sport & Outdoor - Others
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Im having this kind of disconnection problems, before i was using a linksys router i dont have any disconnection problems but because my power adaptor for my linksys router burn out i already stop using it...
Hello
For the Linksys Adapter you can contact any of Linksys support center nearest you or get a compatible adopter from any electronic shop.
and for improvement of your router's signal strength, you may see my tip here http://www.fixya.com/support/r7245572-improve_signal_strength_wireless_network
Good luck, and do rate the solution if got help
Dec 15, 2010 | Edimax BR-6104 Broadband Router. One...
Laptop will not power up.
  • If possible, make sure there is power coming from the power adaptor with a voltmeter. If nothing shows, the adaptor needs replacing or repairing.
  • Try removing the battery and running on the power adaptor alone. If this works the battery is dead. You can buy a new battery or just run it on the adaptor.
Apr 08, 2010 | Gateway MX6450 Notebook
Acer Scan prisa 620U Power adapter is missing. Pls tell me about its picture and its voltage. Thanks Azeem
my scaner power adaptor is missing input :220 v -output:16v 0.9A. IF I USE adaptor input 220v output:16v 3A is there any damage happned to my scanner.plese help me
Aug 15, 2009 | Acer Office Equipment & Supplies
Alternative 4-PIN 12V AC Adaptor
I've got the same problem. Did you finally find a solution?
Jan 25, 2009 | Televison & Video
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
Jan 03, 2008 | Harman Kardon HK206 Computer Speakers
Compaq Armada 7400 AC Adaptor Pins
Below is the URL for compaq's Service Manual for that model. This shows you the details of every single part & how to disassemble and reassemble every screw. Surely it has to be in this document, somewhere. --> ftp://ftp.compaq.com/pub/supportinformation/forum/portables/7400msg.pdf
Aug 04, 2007 | Compaq Armada 7400 Notebook
Linksys EtherFast Cable/DSL Router Logo
171 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
