Question about Dell OptiPlex SX270 PC Desktop
Computer fails to start
My Dell Optiplex SX270 fails to start when I press the power button. I made sure all cables were secure, which they were. I then saw that the light on the adapter was green so I knew it was getting power, I then saw that on the inside of the computer an orangish, yellowish light was on, so I knew the CPU unit was recieving power, but the unit still failed to start. Please help me
  • 3 more comments
  • Torner Nov 19, 2007
    No it does not display anything. The fans fail to turn on. I was wondering if maybe the button just got stuck or broke.
  • Anonymous Nov 19, 2007
    I have the exaxt same problem, I this just started after I finished my move.
  • im no Nov 21, 2007
    i have the same fault and i have changed the powersupply and motherboard that were working fine before i cant understand why as everyrthing is on the board any ideas anyone
  • musaazi Oct 29, 2008
    it doesnt start yet light inside is on.
  • Anonymous Feb 21, 2009
    I have the same problem. Ive tried two power supplies, their power light indicator do not turn on with either, nor does the computer power on when plugged in.
    I could possilbly have two bad power supplies, but I did see the mobo light flicker when I plugged in the adapter.
    Maybe both the supplies are bad, maybe not.
I'm reasonably sure that it is a bulging or bad capacitor issue. We have had Dell replace a large number of motherboards on SX270 and GX270 computers, due to underpowered or counterfeit capacitors on a large batch purchased back in 2005. The capacitors swell or burst until the computer will not turn on anymore. You'll get the amber light inside the unit, plus a green light on the power supply, but the computer will not power up. You can try the solder technique, but you'd be better off replacing the system board, if possible. Happy trails!
Posted on Nov 28, 2007
I have seen the same probelm on other dell computers. They have a problem with ther capasitors that dryes out. If you open the computer, it is possible to identify the bad capasitors, the have a round top (normally flat). It is normally 6 to 8 capasitors, that are faulty.
A repairkit can be bought and if you have experience in soldering, then the computer should work after replacing the capasitors. I did it with success
The problem is that the capasitors used aren't specified to be used in this temperature range and thats why they stop working after a while
Posted on Nov 27, 2007
  • 41 Answers
HI Torner,
Does it display anything on your monitor?
(if yes then please continue)
Do you see BIOS load when you start your computer?
(if Yes then answer the next question please)
When booting up do you receive any kind of error message (ie. Hardware Failure, Could not load Operating System).
Posted on Nov 18, 2007
Alert chipset heat sink not detected
Turn the computer off.
Disconnect the AC power.
Open the case.
Check that the heat-sink is securely and tightly connected where it should be.
May 07, 2010 | Dell OptiPlex SX270 PC Desktop
How do you install a hard drive to a dell optiplex sx270
This computer only has one space for a 2.5" hard drive (IDE ATA100). Unplug all external cords from the computer (including the power cord) and press the power button (this grounds the system board). Remove the mounting plate and cable cover if these are attached. Place the unit on its side with the back connectors towards you (power supply to the left) and slide the release button towards the right. The hard drive door should open. Ground yourself by touching unpainted metal on the case. Rotate the door up and remove the data cable from the drive (carefully). Raise the release tab (on the opposite side from the data cable) and pull the drive up and away from the door. If you need to, remove the sled from the old hard drive (4 screws, 2 on each side) and attach the sled to the new drive. (If the new drive came with a sled, skip this step.) Slide the new drive onto the drive door. Attach the data cable carefully to avoid bending the pins (just the ribbon section is used, the other 4 pins are left bare). Slide the drive into the drive bay and lower the door to lock it into place. Replace the cord cover and mounting plate if in use and connect all of the external cables. Plug the network cable into the wall jack, router, or modem before connecting it to the computer. Follow the directions that came with the drive for any software installation. Reboot the computer, partition and logically format the hard drive. See the OS documentation for this step. Test the hard drive by running the Dell Diagnostics, . Install the OS for your system.
If the chassis alert comes on at the next reboot, reset it (contact IT if there is a password on the BIOS).
I hope this helps.
Apr 26, 2010 | Dell OptiPlex SX270 PC Desktop
Nedd dell sx270 extension nmonitor cable
go to
Sep 28, 2009 | Dell OptiPlex SX270 PC Desktop
Won't turn on - power led comes yellow & blinking
Please perform the steps mention:
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. Good Luck.!!
Aug 27, 2009 | Dell OptiPlex SX270 PC Desktop
the power supply is probably bad. It's really hard to tell without a little more information. When my power supply went bad on my computer. the hdd light would come on but nothing else and the computer would not even try to start.the power supply puts out several different voltages with both positive and negative outputs.
Aug 01, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell sx270 desktop when I plug it in only the fan works
First of all, keep the front button pressed until the system shuts off. It might be one of several causes:
1) Memory module damaged (or dirty)
2) The processor is damaged, or
3) The motherboard parted off.
Remove the memory modules and test them one by one. Or if you can test them in another PC (assuming both PCs use the same kind of modules).
May 01, 2009 | Dell OptiPlex SX270 PC Desktop
Computer does not start. Replaced motherboard and RAM. Hear the fan when I start the computer
The monitor has the problem. the message only means, the connector is not properly connected on motherboared . please try another monitor.
I am sure about this...monitor or the connector ( as u have changed the motherboard) of the monitor has the problem.
Apr 19, 2009 | Dell OptiPlex SX270 PC Desktop
Hou do i reset bios on a dell optiplex sx270
  1. Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
  2. Press 'ALT' and 'F' at the same time
  3. Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
  4. Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Apr 02, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
Dell OptiPlex SX270 PC Desktop Logo
429 people viewed this question
Alun Cox
