Question about Sony Playstation 3 (PS3) Console
My controler just blinks 4 lights then dies doesnt go to the 1 place it is pluged in while I charge it every day
  • 198 Answers
Try plugging it into your USB drive in your computer overnight.
Posted on Jul 16, 2009
My battery was replaced on 2001 jimmy died while driving and it wasn't the alternator but now it dies when I take my foot off the gas pedal
sounds to me like you should be looking at fuel system ,fuel pump, pluged fuel filter or possibly a bad tps (throttle position sensor) it doesnt sound like it has anything to do with charging system
Dec 01, 2014 | Cars & Trucks
Battery light on, got new alt., starter tries to engage, but doesnt
Did you have the charging system diagnosed or did you just guess at it being the alternator . The charging system is computer controlled . The starter isn't working because low power , battery dead . Is there B+ voltage at the wire on the back of the alternator .B+ voltage at pin 3 at the connector pluged into the alternator .
Charge the battery use a volt meter an test for B+ voltage at the places i mention . No check engine light ? DTC'S - diagnostic trouble codes stored .
Ford Smart Charge System Alternator Not Charging
Ford PCM controlled alternator testing
Aug 26, 2017 | 2004 Ford Focus
When pluged in my ego-ctwist cig isn't showing its charging the light just stays yellow not blinking
Your lighter may have a short or is not pulling enuf power to charge you ego
Feb 06, 2013 | Electronics - Others
My ps3 controller doesnt connect with my ps3 :( . when i press the ps botton no lights come .but when i charge all 4 lights blink .please help !!!!!!!
I had just fixed my controller with that problem. Theres a tiny hole on the back of the controller. That is the reset button. Get something really small and thin so it can hit the button. Once done turn on your PS3 and plug up the controller with the usb connector. Once done press the PS button then it will start blinking and then assign a controller number
May 29, 2012 | Sony Dual Shock 3 Controller for...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
My pc is not turning on (all the light does is blink orange)
Woops -the blinking amber light of doom is a common fault on dells -
usually a solid amber is the Power supply while a blinking one indicates Motherboard problems. If machine is still under warranty dell will replace it.
If not then it will cost you to have them replaced.
Dec 07, 2008 | Dell Dimension E520 PC Desktop
My phone isnt charging and the light for the charger is blinking
Yep, common problem with this phone. Charging circuit controller (small IC on mainboard has died) not worth repairing. Go out and buy another $30-$40 phone - there are better models and choices for replacement these days.
Dec 05, 2008 | GE 27998GE6 Cordless Phone
My Shaver battery doesn't fully charged
Hi... I have the same problem, I got my shaver 2 days ago, and it is written that you need to charge it for 4 hrs in the first time and then the light willl start blinking as an indication that the batery is ful !!! I noticed the following :
1- After 15 Mintues the light simply turn off without any blinking !!!
2- The shaver is charged and runs for almost 1 hrs !!!!
Is this is a fault ??? shall I bring back ...
Please answer me what was your case ??
Mar 20, 2008 | Braun Cruzer 3 Electric Shaver
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
