Question about Xerox Office Equipment & Supplies
Won't make copies. The display shows a red circle lit up. This is a xerox workcentre XD105f. I'm thinking that the error might be the drum cartridge, but I don't have a manual or anything to tell exactly what the problem is. Is there a way to trigger an error code that will identify exactly what part I need? Thanks, Bob tenor165@aol.com
    President:
  • 2,072 Answers
Yes that is the drum life indicator, The toner indicator is a triangle.
Posted on Jul 16, 2009
I have a workcentre pro 215, this have a circle red light on, somebody could help me? thanks
That is the signal to reaplace the drum cartridge. It has a life of 18-20 thousand pages and then that light comes on meaning it needs replaced.
Mar 08, 2010 | Xerox WorkCentre PRO-215 All-In-One Laser...
Flashing J2
j-2 is usually a paper jam at the drum assembly just before the fuser, or jam at the fuser exit sensor. Most times the fuser needs replacement.
Nov 06, 2009 | Xerox WorkCentre XD105F Laser Printer
J2 ERROR
Replace the Drum Cartridge.
Jun 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
thanks
Derek
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Need Drivers for Xerox XD105F for Vista - Do any exist and where
try this link > http://drivers.softpedia.com/progDownload/XEROX-Printer-WorkCentre-XD105f-501230001-Download-2253.html
on the right side there is a DOWNLOAD LOCATIONS
for XEROX Printer WorkCentre XD105f 5.01.2300.01: and below is EXTERNAL MIRROR, click this mirror and save the file. Scan the program prior to your installation, file size is about 4MB. Let me know if there is any other i can help. regards. cebuwano
Apr 11, 2009 | Xerox WorkCentre XD105F Laser Printer
After re-filling the cartridge, some the ink getting inside the copier. I took both the cartridge and the drum part out and cleaned them off with a cloth of the excessive ink. I wiped the round drum part...
The drum should never be touched with anything; the surface is sensitive in the extreme and I suspect you have finished it off.
The refilling of the toner cartridge isn't really a DIY job on this unit.
Yes, it will cost a few dollars but it's either this or a new unit. Although now retired, I had very good service from Precision Roller and I can recommend them highly:
Xerox toner & drum cartridges
Mar 04, 2009 | Xerox WorkCentre XD105F Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
