Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tuning new channels into television
Why cant I auto tune 2 new television channels on my television.i have tried several times with no luck the channels are 76 and 13
  • twowheelin
    twowheelin Mar 04, 2016
    Hi Shirley Plester, I want to help you with your question, but I need more information from you. Are these over the air channels or are you receiving with a cable box or something? Please check that the channels have not previously been blocked and confirm if they are digital or analog channels.
  • Shirley Plester Mar 04, 2016
    they are new free to sir channels, my television is attatched to a new outdoor aerial.the channels are channel 13 and channel 7fliks channel 76 thank you
5 Suggested Answers
SOURCE:
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
Thompsons196
  • 350 Answers
SOURCE: i have recently bought a
Does it have a built in digital tuner? unplug wait 5 minutes hold power button while you plug it in you should get into a secret menu usd by techs look and see if you have a digital tuner hope that way works for that set
Posted on Jan 27, 2011
  • 406 Answers
SOURCE: Am getting an incompatible video signal message when trying to tune in new TV digital channels on a sharp aquos tv
You will need to switch frequency. Check your manual on how to do this.
Posted on Mar 13, 2016
Tuning new tv channels
You can't just tune the new channels on most Tv You have to tune the whole set, go to settings select D T V and ok. If you have done this and still have missing channels the signal me weak, you may have to buy a high gain aerial.
Mar 03, 2016 | Televison & Video
I get sound on new channel but no picture with invalid format across the screen. Why ??? What does this mean
the format used when you tuned is incorrect
the correct way is to go to the onscreen menu and find the tune section and go auto tune
allow time for the auto tune to find all channels then exit
Mar 01, 2016 | Televison & Video
Can tune in new stations
press the menu botton on the remote go to onscreen menu , find the auto tune section ( volume and channel selectors on the remote)and press auto tune
allow it to run its course and all channels will appear
Have tried to scan in new 7flix channel just now no luck im in Noosa Heads help?
channel 7 have issued a press release that there will be problems getting it to tune in 7 flix til around wednesday
wait until tuesday as channel 9 live will be coming online as well so when you auto tune from the screen menu , it will tune in both stations
Feb 28, 2016 | Televison & Video
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Televison & Video
Cable to antenna mode
You will have to use your remote control and go into the menu. In the menu you will see several options . One will be auto tuning. Go to auto tune or tuning channels. Good Luck
Jun 27, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
130 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
