Question about Dell Optiplex GX280 (99301) Motherboard
I have a dell dx280 when I start the pc. I can see some simbols in the bios screen, after that I try to install windows xp and in the process appear a blue screen with error message about hardware problem. I install this hard disk in other comutera and I didn't have any problems. What Can I do
    President:
  • 1,383 Answers
First refix RAM memory . then try to install windows xp 5 times untill you can.
i also face same problem it is due to memory related so i refix RAM and try winxp install 3 times and i succeded.
Posted on Jul 16, 2009
  • 788 Answers
The Dell Dx280 is a P4 2.80 ghz. Processor
If you can boot into the BIOS setup screen without any trouble, your problems may be memory or drive configuration. ( Start from scratch ) Disconnect any external devices.
1. Set all BIOS controls to Default.
2. On your other machine, make a bootable disk (CD).
3. Check your BIOS version against current versions available.
4. Make sure your BIOS will accept the Drive Size and Structure.
5. Find out what version of VISTA you are running... ect. 32bit or 64.
Partition and Format your hard disk using a HD utility, such as Sea tools or Disk manager.
6. Try loading appropriate version of VISTA to drive.
If after Partitioning drive, you are still getting errors, remove or replace memory, one piece at a time.
If your BIOS is corrupt, you may have to Flash the BIOS to Factory specs. first and then again to current versions.
Hope this has helped, if you cant load the simple stuff, the Hard Stuff will never load.
Readers, please rate your technicians
Thanks.
John Ray
john@johnrraycomputer.com
Reset bios
Installing a fresh operating system is a good option, and there might be a feature in the BIOS to restore the system to factory defaults. Information on how to do this:
Windows XP: Dell PC Restore
Using PC Restore:
1. Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top
of the screen.
2. Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish
starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot.
3. Click Restore and click Confirm.
The restore process takes approximately 6 to 10 minutes to complete.
4. When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer
completely reboot.
5. When prompted, click Yes.
The computer restarts.
Because the computer is restored to its original
operating state, the screens that appear, such as the End User License
Agreement, are the same ones that appeared the first time the computer
was turned on.
6. Click Next.
The System Restore screen appears and the computer restarts.
7. After the computer restarts, click OK.
or
http://www.user-guides.co.uk/download/dell/delloptiplex/dell-optiplex-330-reset-bios-password.html
Aug 18, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
I can't install the windows xp. when i am install windows xp then appeares a blue screen error. there is no option to change the sata mode from bios setup. please forward to me how to change the sata...
when the computer is booting, try pressing one of the keys.F2 or F12.
OR when the Dell Screen appears look at the bottom of the screen, it should be written down somewhere on the far right or far left.
Hope this helps!
Jul 27, 2011 | Computers & Internet
Several attempts to install windows 2003 on dell optiplex 780 have been unsuccessful. all i get each time is a blue screen.
Windows 2003? There is no operating system called "Windows 2003". There is Windows 95, Windows 98, Windows ME, Windows 2000, Windows Milenium, Win Xp, Win Vista, Windows 7 ect. But no Windows 2003.
If you are trying to install an operating system on a Dell computer, put the disk in the cd or dvd drive on the pc and close it. Then turn the computer off and reboot it with the disk in the drive. After the computer reboots, it should recognize the disk in the drive and bring up the installation process automatically. Sometimes you have to reboot the computer 3 - 4 times in a row with the disk in the drive in order to get it to recognize the software and boot from that drive.
If the Dell does not have an operating system on it and you are trying to install windows from a disk, it may not auto recognize the program in the drive and the above instructions will not work. If this is the case, then you need to put the disk in the drive of the pc and restart/reboot it - and watch the computer screen as the pc restarts - look at the lower left side of the screen during the boot up process to see what keys you need to press to enter startup mode, or get into the bios system of the computer. when you boot up a pc, it will display the keys you need to press on the screen for a brief few seconds before the "windows" screen appears and it completes the start up. If the pc is running windows xp, the command keys to press during start up might be F2 - F8 or "press the delete key". The commands can differ depending on which version of windows you are using - and they can also vary by brand of pc too.
You need to put the pc into "safe mode" or get into the Bios system or restore area to install windows if the computer does not already have an operating system installed on it.
To put the pc into safe mode or get into the Bios System, you need to press the right keys during the start up - and do this before a picture appears on the screen or the windows display comes up.
Put the disk in the drive and reboot the pc. As soon as it starts to reboot, keep pressing the F8 key. If the pc does not go into Bios or say "loading safe mode" then immediately restart the pc and try again. Sometimes it takes 3 or 4 attempts to make this happen. If the F8 command does not work after 4 tries, then try the F2 key. After four tries if that does not work - try pressing the delete key.
If you can get the pc into the bios system - use the arrow keys on the keyboard to scroll through the options and find the prompt that says "boot order". change the boot order to boot from the Cd or Dvd drive instead of the hard drive. Save after changing this setting and reboot the pc with the disk in the drive and it should boot from that disk to install the operating system. Try rebooting 2 or 3 times after changing the boot order to the disk drive to get it to boot from the cd. Then just follow the prompts to install the operating system and your done!
Jul 07, 2011 | Computers & Internet
Hello. I'm going to do a manual reinstall of windows xp on my Dell Vostro 200. I wanted to know at what point should I install my virus protection. Should I install the virus protection after installing...
you should install the driver for the network first ..so to be able to install the antivirus ..cause most of them need internet connection for a complete and correct install...and after that the first thing is to install the protection cause during the installing of any program the computer communicate with the net and you are in danger ..so ...in principle you should install the protection first ..but this is not possible unless you have a on board lan card that installs itself from windows..
after you make the internet communication ..first thing is to protect yourself..
Oct 01, 2010 | Dell Vostro 200 PC Desktop
Dell Inspiron 530s/531s desktop, Win. Xp home...Windows stops responding at the ''Loading Personal Settings'' cannot boot in safe mode.
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
Mar 27, 2010 | Dell Inspiron 530 Desktop Computer
No Dell Logo on the LCD screen while starting the computer
I would suggest you to try doing a BIOS default settings
Immediately after you start the computer start hitting F2( or Delete key in some systems), It will take you to BIOS. Just load the default settings for BIOS save settings and exit.
This should resolve your issue
Oct 03, 2009 | Dell Latitude D620 Notebook
Wont load win xp on gx 260
There are a number of reasons why XP won't install or hangs halfway through the install process.
The main culprits are bad sectors on the hard drive. Poorly seated or faulty system memory and of course scratched CD or a dirty optical lens.
You are going to have to go through this troubleshooting process to determine what the problem is and what you have to do to resolve the problem.
Start by cleaning the install disk and the optical lens, remove and clean the system memory and the slots, check the cables and then try to reinstall.
If you run into the same problem i would be suspecting the hard drive.
As far as i know Dell have their own utility.
Turn on the computer. When the DELL™ logo appears, press <F12> immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again.
When the boot device list appears, highlight Diagnostics and press <Enter>.
If you don't have the Dell Diagnostics Utility on the computer then something like Hiren's boot CD will be able to check the drive for errors in the hard disk tools section.
Regards.
Sep 29, 2009 | Dell OptiPlex GX260 PC Desktop
Reformatting pc
what you need to do is put the XP cd in the cd or dvd drive first,then, when the pc is booting up press either F2 or Del depending on bios and the cmos setting screen will appear. Go to advanced cmos settings and the top line normal reads 'first boot device, this will be set at HDD or hard disk, this needs to be changed to cdrom. When you have changed it, save settings and exit, the system will now reboot and an option to boot from cd screen will appear, you then press Enter to boot from cd then follow the instructions to format or install windows.
Aug 27, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
448 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
