Question about Kenwood KDC-MP228 CD Player
Kenwood KDC-MP228 satellite radio set-up
I am trying to set up my player which I don't have a manual to go through. Maybe You can help by listing any steps.
  • 78 Answers
If you look on the kenwood electronics web site there is a section on instruction manual downloads
Posted on Nov 22, 2007
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
Cyber home LT0150-A remote code
You don't set the player for codes. Its codes are not user changeable.
What you do is set the universal remote for the code in its code list that is for your player.
Universal remote brands (sometimes even models) use different code libraries, so you need to use the code list specific to that universal remote. It should come with one in a boolket, and good universal remote manufacturers provide their code lists online. Ok sir try this site perhaps it will help you just click the link and you will see different procedure on how to unlock your cyberhome. Perhaps it will help you.
Jul 10, 2011 | Cyberhome CH-DVD 300 DVD Player
Cannot be reconized by computer, ie states no device connected
Try other USB ports on your computer. A USB port behind a PC usually has the most power output. Try a different cable if there's one available, to rule out a cable malfunction. Try another computer.  NEXT - Refresh the drivers STEP 1 - Connect the Sansa player to the PC STEP 2 - Check under Device Manager -> 1. Right-click My Computer, and select Manage. NOTE: The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode.)
See this tip posted here on this site. This might be what is going on with your player.  http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.  STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. A brand new Sansa player NOT recognized by the computer when plugged in: This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.   To resolve this issue, try the following solutions: Verify if minimum operating system requirements are met.
Operating systems supported by Sansa players: Windows Vista and Windows XP SP2
Windows Media player supported by Sansa players: Version 10 and 11 Download and install the latest Windows Media Player if it's not installed.
For MAC users, see Sansa player not recognized by a MAC OS Next Connect the device to the PC in MSC mode View/c200:  Turn on then press and hold the rewind button while plugging to the PC  See List of Sansa players with instructions on enabling MSC mode
If all this has failed - Refresh the drivers
STEP 1 - Connect the Sansa player to the PC STEP 2 - Check under Device Manager 1. Right-click My Computer, and select Manage. SOLUTION 4 - If that didn't work, and you are running Windows Vista, verify if you have Service Pack 1 installed.   If all that does not work - Manually add the hardware driver. STEP 1 - Connect the Sansa player in MTP mode STEP 2 - Manually install the device driver 1. Click Start select Control Panel then select Add Hardware. 2. Click Next to begin the Add Hardware Wizard. 3. Click Yes, I have already connected the hardware, then Next. 4. Scroll to the end of the list and select Add a new hardware device then click Next 5. Select Install the hardware that I manually select from a list (Advanced) then click Next 6. Select Portable Device or Windows Media Device from the list, then click Next 7. Select MTP device, then click Next. 8. Click Next to start loading the drivers. 9. Click Finish to close the wizard.
STEP 3 - Verify if the device is detected properly 1. Double-click My Computer. 2. Check if the device is showing up under Portable devices. SOLUTION 6 - Set user restrictions.
Some computers have user right restrictions that are set to disable access to new hardware. STEP 1 - Log-in as an Administrator STEP 2 - Edit restriction NOTE: Disconnect the Sansa player if connected. 1. Click Start then Run, 2. Type cmd, then the press Enter. 3. After the prompt, type Net localgroup Administrators local service /add then press Enter.
STEP 3 - Reconnect your device
Jan 10, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
I need the codes for Magnavox CD player
To control a Magnavox DVD player with a One for All URC-3021, follow these steps:
1) Turn on your DVD.
2) On the remote, press the DVDkey once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0503, 0675
5) Aim the remote at the DVD and press POWER.
Hope that helps.
Oct 29, 2009 | One For All URC-3021 Remote Control
Need the program code for audivox avd300
The code for a URC-3021 to control an Audiovox DVD player is not listed in the manual. These are the steps to run through all the DVD control codes to find one that is compatible with your unit:
To setup your URC-3021 for the DVD player, these are the steps:
  1. Turn on your DVD player.
  2. On the remote control, press DVD once.
  4. Enter 9 - 9 - 1.The LED will blink twice.
  5. Aim the remote control at the the DVD player and slowly alternate between pressing POWER and DVD. Stop when the DVD player turns off.
  6. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 24, 2009 | One For All URC-3021 Remote Control
Don''t no where to fill the gear box on a ford laser
try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 22, 2009 | 2006 Ford Laser
How do i delete music off my sansa mp3 player?
Source: http://www.ehow.com/how_2023687_delete-files-sansa.html
Step 1Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. Step 2Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory. Step 3Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. Step 4Click on single items or click and lasso multiple files. Step 5Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. Step 6Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs. Tips & Warnings
  • Optionally, you can left-click on a file and drag the file icon to the Recycle Bin. Either way, you can delete music that you don’t want from your Sansa MP3 player.
  • Unlike other documents and files, once the music file hits the Recycle Bin, it’s gone. Make sure that you are deleting the correct file.
For more help: http://www.supportrix.com/
Jul 30, 2008 | Audio Players & Recorders
I have an 8 GB Creative Zen V Vision. The player is frozen. I can't take out the battery because it is a permanent battery, unable to take out by any means. I have tried to turn it off, and I have tried...
Did you try the reset method suggested in your user's manual? Creative does not list a reset method on their website.
If that fails:
Step by step instructions for formatting a player
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Jun 14, 2008 | Audio Players & Recorders
I want tracks from alphabetical to album order...
Try renaming the tracks on your PC with a two digit track number at the beginning of the title, e.g 01 - Track name.
Re-load the tracks on to your player and use the album list to play them.
Jan 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Kenwood KDC-MP228 CD Player Logo
101 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
