Question about Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven
Oven will not get hot
My frigidaire oven will not get hot. I just bought it a week ago.
SOURCE: Frigidaire Wall Oven does not open once hot
Well at least I seem to have solved it. I kept hitting clear off and tugged on the door and it finally opened. Once opened I noticed there is a metal hook at the top of the opening to the oven. Mine was rotated to the 9 o'clock position. I took a pair of pliers and rotated it until the open part of the hook was in the 12 o'clock position and tugged outward on it just a bit and the "door locked" signal went off. I hit clear off again and the beeping has not resumed. I'm thinking the hook got partially stuck in the wrong position after it automatically locked the door for cleaning.
Waiting for the oven to completely cool off before I close the door again.
Hope this helps someone else out there!
Posted on Jan 08, 2009
0 characters
1 Points
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
Oven not getting hot
I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
Jan 13, 2012 | Frigidaire Ovens
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Aug 24, 2010 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
No power on the disply panel
replace the control clock its may be under warranty,,check the last page in owners manuel,,,
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Oven Light won't shut off
Amazing, I had the same problem, was told the same thing, even quoted the same amount!   There must be a playbook with stupid answers by repair people.  Anyhow, here is how I unlocked my oven:  "Press and hold the 'Lock' button for 3 seconds then let go and it should unlock in about a minute."  Hope this works for you. Don
Nov 13, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven Logo
32 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
