Question about Dell 3130cn Color Laser Printer
Error code 093-921
Dell printers appear to have a common fault but provide no answers yet. I refer to error code 093-921 which supposedly is caused by a tape on the toner.. this one is the cyan toner and there is no tape on it
  • Joe Howarth
    Joe Howarth Mar 04, 2016
    SOLUTION FOUND!!!!!!!!!!!!!!!!!!
  • Joe Howarth
    First, I want to share with all that these toner cartridges are used with Xerox 6180,6280,Lexmark X560 along with Dell's 3110,3115 and the 3130 (AT LEAST FROM WHAT I CAN TELL).
    This is how I got mine to clear the error code and PRINT!!!!
    REMOVE THE TONER CARTRIDGE and look with a flashlight into the slot where the protective tape used to occupy. IN my case the particular cartridge was the cyan or the C cartridge Dell identifies it. Inside that slot was a film of blue toner powder but more importantly, there is also what appears to be an led sensor. This sensor is located exactly where the protective tape is secured to the cartridge. This sensor also had toner powder covering it.
    I used a very small wound on wire brush, one typically used to clean holes in paint spray guns. Next I used the brush as best I could to clean that slot especially around the sensor.
    After brushing I used my air compressor to blow out that slot. NOw even brushing and blowing out that slot there was still blue residue present but not much. I do emphasize that the area around the sensor was very clean.
    INstalled it into the printer, turn the power on and expected the same error code. TO MY HAPPY SURPRISE, THE PRINTER RESPONDED "READY TO PRINT!"
    I do want to share with all who has been badgered
    with this BPITA problem.
    ENJOY!!!!!!!!!!!!
    Joe Howarth
  • Dell Master
  • 1,680 Answers
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Posted on Mar 02, 2016
Testimonial: "Thank you for your reply. I already tried doing the toner cartridge test and it passed. Each time the cartridge was removed and replaced, the count increased. I tried the service manual which has a flow chart for this problem. The last step is to replace the printer. Yes, does seem excessive. Googling shows this problem is numerous and must be well known. I don't know how the machine senses a cartridge tape but if I knew I would go look for the sensor. I do have a new cartridge scheduled to arrive early next week. And no, I am not using Dells expensive cartridges. Somehow I think it is specifically related to that. I can't access the menu with a fault present. If I am able to get that fault cleared I will set the printer for non Dell toner which at one time was recognized and identified in the display window. If I have to junk this printer with less than 30,000 prints, it will be the last Dell anything that I will purchase in the future."
  • Ravi Mar 05, 2016
    Thanks for updating your findings and solution.
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Xerox error code
There is a bulletin from Xerox that helps to troubleshoot and identify the error. If you provide me your e-mail address I will send it to you. Please e-mail me at sales@iteminc.com.
Sep 16, 2014 | Xerox Phaser 8560DN Laser Printer
From a stop engine is running fine (not over speeding) but vehicle starts slowly as if on wrong gear
code p0740 refers to torque converter clutch (TCC) solenoid --circuit malfunction Causes---Wiring---TCC solenoid--- ECM/TCM
Code p2716 refers to transmission fluid pressure(TFP) solenoid D-electrical Causes---Wiring---TFP solenoid.
Code p0785 refers to shift/ timing solenoid circuit malfunction Causes---Wiring---shift/timing solenoid---ECM?TCM The common fault here appears to be the TCM ( transmission control module) have it check out..
Apr 07, 2013 | 2005 GMC Sierra
Error H 98 on Panasonic microwave
Hi, just Goggled for an answer and it appears to be common with this model microwave......refer it to an authorised technician as it may be the magnetron at fault.
Dec 20, 2012 | Microwave Ovens
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
What is error code 5200?
The error code 5200 refers to a common windows error caused by misconfigured system files which indicate that your system is having a corrupt registry entries.
I hope I answered your question and if ever you need help with this error code, feel free to contact us. Thank you for choosing FixYa!
Apr 22, 2011 | Canon PIXMA MX340 Wireless Office...
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
Check engine codes for a 1997 stratus the codes coming up are 12 31 and 55
12 Recently disconnected the battery (always stored)
55 End test.
CODE 31... depending on the model, code 31 can refer to two different systems. Please choose from one of the above links for specific information on each system.
Wastegate Solenoid Circuit Error
The ECM regulates turbocharger boost by opening and closing the "wastegate" as necessary. (The wastegate is a vacuum operated bypass valve that limits the ability of the turbo to provide boost.) The Wastegate Solenoid regulates the vacuum supply to the wastegate for proper operation.
Fault Code Description
  • 31 - Wastegate Solenoid circuit error
Symptoms
  • Lack of power or engine "ping" due to overboost by the turbocharger
Common Problems
  • The wastegate solenoid would be the most common cause for code 31 to set
  • Code 31 does not indicate a problem with the turbocharger or wastegate
Gear Position Switch (PRNDL) Error The Gear Position switch tells the ECM which position the shifter is in. The ECM will use this information to inhibit starter operation, change the transmission shift pattern as necessary, and provide the information for the electronic shift indicator display on the dash.
  • 31 - Gear Position switch (PRNDL) error
Symptoms
  • Engine may not crank over in Park or Neutral
  • Electronic shift indicator may flash
Common Problems
A maladjusted or failed Gear Position switch would be the most common cause for a code 31
Hope helps with this (remember rated this post).
Jun 30, 2010 | 1997 Dodge Stratus
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Dell 3130cn Color Laser Printer Logo
1,061 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
