Question about ASUS A8M Notebook
CAN I UPGRADE THE HARD DRIVE IN MY ASUS A8M LAPTOP, EXAMPLE CHANGE THE 80GIG DRIVE TO A 160 GIG
  • ASUS Master
  • 6,487 Answers
Yes you can upgrade the hard drive from 80 to 160 GIG SATA for you to have more storage for your computer files....
Posted on Jul 16, 2009
Hi there , i have an acer travelmate 6592 laptop , the original 80 gig hard drive crashed , and i dont have the recovery disc , the hidden partition wont re install either , i have bought a new 320 gig...
You cannot get the full 320Gb capacity because the BIOS can only support a maximum of 127Gb.
You only hope is a BIOS firmware upgrade that can support 320Gb. Check out the Acer WEB site to see if a BIOS upgrade will solve your problem.
OTHERWISE
Install a 127Gb hard drive in your Acer and put the 320Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive because it is not affected by the BIOS limitation.
Jun 13, 2011 | Computers & Internet
TAKEN OUT A TOSHIBA 80GIG DEAD DRIVE, lAPTOP
It is an IDE hard drive. Thr IDE drive will have a double row of 44 data pins
Mar 29, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
How do I choose a hard drive for an upgrade?
You want to make sure you buy a Serial ATA hard drive as for storage space it depends on what you use it for. if you save a lot of pictures and other files you might want to go with a 320 gig or more. other than that if you are just looking to replace the current one and I would order a 160 gig. But make sure it is a Serial ATA when looking. I like seagate and maxtor for hard drives.
Jan 10, 2010 | Samsung Q45 Notebook
I have a motherboard that has only has one ide conncetions
what you should do is make the 300 gig as second drive and your primary drive is the 80 gig so that you can view and back-up the contents inside it. If you going to install a new copy of Operating system that would be in the 80 gig so that you don't need to format your 300 gig and make it as second drive. Hope this could help you..Thanks..
Oct 24, 2009 | Computers & Internet
I have a panasonic cf-51 with 40-gig drive. I want to upgrade the drive with something at least 160 gig. Do you have any drives available? What spec should I be looking for?
Basically, any EIDE interface hard drive will work, if you buy a new drive, just make sure to use the included software to boot the laptop up with in order to initialize the new disc and make it useable on your system.
Sep 27, 2009 | Panasonic Toughbook CF-51 Notebook
Upgrading my Dell Inspiron 8200 laptop
I have a Dell Inspiron 8200 P4 2.4ghz and I install 2gig or ram and it works great ddr pc2700 333mhz for $69/gig at bestbuy. I really notice the difference. I also install a 160 gig HDD.
Mar 17, 2009 | Dell Inspiron 8200 Notebook
To upgrade my Asus Eeepc 4G
The only way you can add space is for you to use an external HDD because an Eee PC has a built-in hard drive that cannot be upgraded.
Dec 07, 2008 | ASUS Eee 4G Notebook
Changing HHD on Averatec 5500
Hi Sunergos!
Replacing the drive is real easy! Diconnect the power and remove the battery. On the bottom of the laptop, lower right hand side, you will a panel, with one screw. Remove the screw, and lift the panel. The drive had a plastic pull tab on it. Lift up gently, and pull to the right. Don't lift too high. The drive will come right out. The Drive is held in a "tray" with four little screws. Remove those, and place the new drive in the same way. Just reverse the procedure, to install it, making sure the pins line up the with the female connector. Hint - wait 10 min or so before putting the drive in, or it won't recognize it. Newegg has a 120 gig drive for that lappy for $74. Upgrading my Averatec 5500, I ended up with a 3400+ CPU, 1 gig ram, and a 120 gig harddrive, that dual boots to Vista or XP, and is just as fast in either OS. Good Luck!
Dec 03, 2007 | Computers & Internet
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
ASUS A8M Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
